Need advice regarding tankless (or other) WH for cabin
Discussion in 'Tankless Water Heater Forum' started by Catherinew, Aug 13, 2010.
  1. Catherinew
    Catherinew New Member
    Aug 13, 2010
    Baltimore MD
    I own a cabin that's been in the family for three generations. We have well water and have never had an indoor bath or hot water. We are putting in a bathroom, and I want enough hot water for sponge bathing or warm showers. We don't use it in the winter and it is unheated in the winter months, except for the occasinal visit when we build a fire in the antique stove (its only heat source). There is no washing machine or DW and none are planned. Our needs are therefore simple and I'm hoping to install a simple water heater that will supply enough hot water for bathing. If it's less complicated than stove-heating water for dishes, we will tote hot water from the bathroom to wash dishes.
    What do you all recommend? Thanks so much. I am totally new to your site and it looks very helpful!
    Catherine
  2. jadnashua
    What energy sources do you have available? What size is the electrical supply (main breaker or fuse)? How cold is the incoming water from the well? Do you have natural gas available or willing to put in a propane tank? An electrical tankless will be limited in volume unless you have significant electrical power capacity - the smallest one might overload your power panel. A tank-type electrical WH is probably the easiest to install and probably wouldn't tax the incoming power. I'd turn it off and drain it for the winter. You must ensure it is full of water prior to turning the power to it, or you will quickly fry the heating element(s).
  4. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    The Bosch 1600H propane fired tankless is about as good as it gets for off-grid & cabin use: No electrical hookup, vents with cheap B-vent, and is nearly as efficient as it's forced-draft microprocessor controlled tankless brethren, is more than enough to run even a HOT shower at 3gpm, and it takes up far less space than a tank. They're as simple to install as a propane fired tank HW heater, but DO pay attention to minimum gas-plumbing pipe diameter/length if it's more than a few 10s of feet from the pressure regulator.
    There are cheaper versions available with battery-powered ignition that come in different sizes from Marey (of Puerto Rico) that look & feel like the same Chinese designs used all over Latin America & tropical Asia, but I like the Bosch better.
    For more money the smaller (electronically controlled) Rinnai units designed for mounting on the exterior of the house are pretty nice, and would take up ZERO interior space.
  5. Catherinew
    Aug 13, 2010
    Baltimore MD
    We have electricity-120 V.
    It's not capable of supporting much, but it runs a refridgerator and a few lights. We are in the process of installing our first, simple running water.
  6. Catherinew
    Aug 13, 2010
    Baltimore MD
    Also, we have propane for a gas stove.
  7. jimbo
    jimbo Plumber
    Your modest electrical supply is not likely large enought to support an electric tankless. Check with your propane dealer on your tank capacity and whether it will deliver the btu's needed for hot water.
Similar Threads: Need advice
Tankless Water Heater Forum Water pressure low and not hot even after fixing broken heating element. Need advice. Dec 10, 2016
Tankless Water Heater Forum Water Heater(s) advice needed Apr 1, 2015
Tankless Water Heater Forum Need advice in replacing water heater(s) Jan 13, 2013
Tankless Water Heater Forum Tankless Water heater problem...advice needed Aug 27, 2008
Tankless Water Heater Forum Water Heater About to Blow - Need advice! Oct 25, 2007
