Need advice/recommendations on stationary and hand-held shower heads
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CindyJ, Dec 1, 2012.
  1. CindyJ
    CindyJ Member
    Nov 20, 2012
    Pennsylvania
    We're installing a new faucet and shower heads in an existing shower. We don't presently have a hand-held shower head, but we'd like to add one on a slide bar using a 3-port diverter system. This is by no means a top-of-the-line bathroom, and I'm not looking for high-end products, only products that will function well, look good and hold up well over time. I don't know where/how to begin narrowing my options, so I thought this would be a good place. What are the brands/models I should be considering? What other considerations I should be thinking about? Thanks!
  2. hj
    NOne of them are what you would call "top of the line", because almost all of them are made of plastic. This being the case, all you have to do is visit bath stores, big box stores, and plumbing showrooms to see what looks good to you.
  4. CindyJ
    CindyJ Member
    Nov 20, 2012
    Pennsylvania
    So are you saying that the quality is the same from one brand to another, and it all comes down to which one's appearance I prefer?
  5. CindyJ
    CindyJ Member
    Nov 20, 2012
    Pennsylvania
    Another question -- I was envisioning having a 3-port diverter, but my plumber is recommending using the Moen A720 Shower Arm Diverter. I know the Moen part is a lot easier (and therefore less costly) to install, and maybe that's why he's recommending it, but does installing the 3-port diverter really require that much more piping and labor?
  6. hj
    It goes inside the wall so I am not sure how much time, labor, or cost is involved, but it will DEFINITELY be more expensive than the shower arm diverter. The only real benefit to the 3 port diverter is that you can make the connection for the hand held anywhere on the wall you want to put it, (assuming you do not mind making a lot of wall repairs).
  7. CindyJ
    CindyJ Member
    Nov 20, 2012
    Pennsylvania
    Prior to installing the new shower faucet and shower heads, my entire house will be repiped. We're switching from copper to CPVC. We learned the hard and EXPENSIVE way that copper pipes + low pH water = disaster. A portion of the wall in back of the shower will be removed for the repiping, so the plumber will have easy access to the pipes for the shower components.
Similar Threads: Need advice/recommendations
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Need 10" skirted toilet in ADA Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Support studs in bathroom need new how do i thread 2 inch pvc pipes thru them Feb 1, 2017
