Kstuart
Hello,
I live in a small rural town where it can get down into single digits in winter. My house has the usual 3 br, 2 bath (both with shower), kitchen, dishwasher, washing machine. The water is provided by a well with an underground (submersible) pump and a pressure tank under the house(but no valve at the tank - however there is an outside hose faucet that happens to be lower than all the plumbing). There is only electricity and we usually heat in winter with a high-end wood stove supplemented by electric oil-filled radiator heaters. The house dates from the 70s, is poorly insulated, has all copper piping (with some fittings of other materials), and all wood construction (no sheetrock).
I am planning on spending the winter (four months) with relatives by the coastside and may eventually move there, as I am getting too old for dealing with the feet of snow that we get here most winters.
Heating the house in winter electrically would cost roughly $400 a month (due to the lack of insulation). Last January, the power was out for four days, so I cannot depend on there being any heat.
My questions:
- What would you do in this situation ?
- How long does it take to do the whole procedure of draining the water from the whole system, blowing air through the pipes, antifreeze into the traps, etc. ? (My relatives are an 8 hour drive, so if it would take me hours to do the winterizing, it might be necessary to have someone else do it anyway.)
- What damage or problems can occur with the house being frozen - even if all the water is thoroughly removed from the plumbing ? In other words, things other than pipes bursting.
Thanks !
My questions:
Thanks !
