Need Advice on water softener Installation
Discussion in 'Water Softener Forum, Questions and Answers' started by ra, Jul 3, 2013.
  1. ra
    ra New Member
    Jul 2, 2013
    Manitoba
    Hi There,
    Can anybody help me out on my water softener installation.
    I`m looking to install my water softener to my house plumbing and your suggestions are very much valuable.
    Can somebody look at the attached picture and give me the list what i need to buy for plumbing the softener to the water line.
    I am mechanically inclined but do not know much on the plumbing side.
    I believe it is not a difficult task.
    Thanks.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Is that really the main water service to your home?
  4. ra
    ra New Member
    Jul 2, 2013
    Manitoba
    Yes, it is the main line from city.
    The size is 3/4" and the line for yard is 1/2"
  5. ditttohead
    Jan 9, 2012
    Ontario California
    The valve is a 5800 series, we need to see the bypass/plumbing connectr to know for sure what you need. I would recommend the falcon John Guest x 3/4" FIP connector if your valve has the 60049 bypass and 18706-02 3/4" plumbing connector. jg.jpg
  6. ra
    ra New Member
    Jul 2, 2013
    Manitoba
    Thanks for your reply Dittohead,
    Hope the picture below helps you to know more about the connection.
  7. ra
    ra New Member
    Jul 2, 2013
    Manitoba
    And also see the 3/4" SS by-pass valve that i will be using 11BJbL6-WLL.jpg 41AVbpXIreL.jpg
  8. ditttohead
    Jan 9, 2012
    Ontario California
    The SS bypass is very high quality and will last for decades. If you use the Falcon 3/4" x john guest flexible adapter, a stainless steel 3/4" nipple is cheap and will convert the FIP threads to an MIP thread that will attach properly to the Falcon Flex line. http://www.freshwatersystems.com/p-...ble-water-connector-34-ptc-x-34-fip-x-18.aspx this is a good source for this item. http://www.mcmaster.com/#catalog/119/6/=ngr3kj part# 4830K193 is the stainless steel nipples you would use.
    Hope this helps!
    Any other suggestions from the real plumbers? I am a certified installer with the WQA and a C-55 contractor, but I am always open to the ideas of guys who do real plumbing for a living every day.
    Dont forget the drain line, just use 1/2" PVC, it is a non pressurized line. Be sure to install a proper air-gap. Test your incoming water pressure to. Do not exceed 80 PSI (UPC 608.2).
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    I'm not real happy with the 3/4" pex. It and the fittings are restrictive as hell. I'm afraid the flow may suck
  10. ditttohead
    Jan 9, 2012
    Ontario California
    Code allows for higher velocity in pex than in copper but... we get calls constantly from people having problems with restricted flow in new houses that have pex. Mainly the showers and bathrooms farthest from the feed pipe. Pex can be run in smaller piping according to code, but some engineers and planners are not taking the frictional losses into account properly or they are under engineering the pipe size to save a few bucks. If I am not mistaken, 12FPS is considered acceptable for Pex, copper is rated for 8 FPS. That is a significant difference. Personally, I will stick with my copper plumbing.
  11. ra
    ra New Member
    Jul 2, 2013
    Manitoba
    Thanks for all your inputs,
    Now i have successfully installed the Softener, but i need your help to program the softener.
    I have the manual it came with it but it`s not that clear.
    Can anybody guide me from the start up as if to plug in the unit and starting at first time.
    your help is greatly appreciated Pro`s,
    Thanks,
Similar Threads: Need Advice
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers Well water test results back need advice for new setup Feb 1, 2017
Water Softener Forum, Questions and Answers Water softener placement advice needed Dec 18, 2016
Water Softener Forum, Questions and Answers Advice needed, well water, plumbing and treatment Oct 14, 2016
Water Softener Forum, Questions and Answers Need water treatment advice Oct 11, 2016
