Need Advice on Shower Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by mm530, Nov 11, 2008.
  1. mm530
    mm530 New Member
    Nov 11, 2008
    I have a separate hot and cold bath faucet system without a shower head. Recently, when I turn on the hot faucet, water comes out but stops. I would have to turn a couple of more times if I want the hot water to continue. By the way, my plumbing is galvanized steel. I wonder what is the cause?
    Also, I would like to convert this system to something like the attached but wall-mount not deck-mount. Where could I find this type of bath faucet?
  2. hj
    faucet
    You cannot just "convert" what you have to that style faucet. It requires revision of the pipes in the wall. Many manufacturers make "wall elbows" to mount that valve to pipes coming out of the wall.
  4. mm530
    mm530 New Member
    Nov 11, 2008
    The attached picture was not exactly the model that I wanted. I wanted one that uses the existing pipes from the wall. I used it initially because I couldn't find one that I wanted. Any help on that?
    Coming back to my first question, does anyone know the problem with my faucet? i turned it a couple of revolutions and water came out, then it stopped. The faucet sounded like something has been sucked out. If i want the water to come out, I need to turn the faucet a couple of more revolution.
  5. jadnashua
    It may be as simple as replacing the washers or tightening up the screw that holds them in place. There could be some crud caught in the line and the flow moves it up against a narrow place, blocking the flow. It might just need to be flushed out.
Similar Threads: Need Advice
Shower & Bathtub Forum & Blog Bathroom remodel issues, need help and advice Mar 16, 2017
Shower & Bathtub Forum & Blog Bad Tile Installer? Need advice Jul 17, 2016
Shower & Bathtub Forum & Blog Need a little advice, building shower pan Mar 3, 2016
Shower & Bathtub Forum & Blog Need Advice: How to Close out top of Tub surround Jan 25, 2016
Shower & Bathtub Forum & Blog Advices needed : Toilet and shower drain Nov 20, 2015
