Need advice on buying a new kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seschroll, Apr 6, 2010.
  1. seschroll
    seschroll New Member
    Apr 6, 2010
    houston tx
    Guys, I need your help here. I live in a 50 year old home with galvanized iron pipes, but they still work fine and I have good water pressure. Ten years ago, I had an inexpensive (single lever, no shower attachment) Delta kitchen faucet installed by a retired plumber neighbor. It's leaking now, and installing a new cartridge didn't help. From what I have read on the internet, new kitchen faucets are made with a lot of plastic parts that can leak. My plumber-neighbor is no longer around so I'll have to hire a plumber. Can you recommend a good, reliable, kitchen faucet without all that plastic that doesn't cost much more than a $100? Thanks Sariah
  2. jimbo
    jimbo Plumber
    You should be able to repair any Delta faucet, for less than $100 in parts. If you want a new faucet, your options are limited. Because of the Jan. 1, 2010 no lead laws, most faucets by most manufacturers are using a lot of plastic. Two brands which have opted to continue with a lot of solid brass, by switching to using the more expensive bismuth alloy, are T&S and Chicago Faucets. Both will run over $100, however.
  4. hj
    Delta sink faucets do NOT have a cartridge, and the only reason to change them, normally, is because you get tired of looking at it, NOT because it cannot be repaired. If your description is correct, someone did not repair it properly, and all you need is a better plumber.
Similar Threads: Need advice
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
Plumbing Forum, Professional & DIY Advice DIY'er Needs Some Advice (I'll air mail some xmas cookies your way...no joke) Dec 9, 2016
Plumbing Forum, Professional & DIY Advice Need advice on repairs of copper pipes at water heater Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Lady needs advice on cutting ballcock stem Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Planning a bath remodel .... need advice Oct 21, 2016
