Need adivce on replacing washer shutoff valves
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by appdude, Feb 5, 2014.
  1. appdude
    appdude New Member
    36
    Ontario
    Well its happening once again but now its worse. The valves for my washing machine are leaking. But I noticed they look they are threaded/screwed on to the pipe. However there is a soldered threaded piece soldered to the copper pipe. Can these be unscrewed? Or soldered off? Could someone please tell me how to remove this?:confused:
  2. that10pin
    that10pin New Member
    NY
    Where are the valves leaking? Is it at the solder joint or at where it screws in.
  3. Terry
    14,759
    You may be able to tighten up the bonnet nuts at the stem.
    Or if you replace, you can heat them and slip them off the copper.
  4. appdude
    appdude New Member
    36
    Ontario
    It's leaking at the stem, I already tried to tighten and the bonnet won't budge. Also do I have to get a new threaded piece? Or can i just re use the old one?
  5. jim mills
    jim mills New Member
    141
    nebraska
    Should be able to re-use the threaded adapter. Get ball valves next time. You can get an adapter that screws into the FIP threads on the ball valve for the hookup hoses.
    THEN...
  6. Terry
    14,759
    You may want to post a better picture where the threads meet the copper.
    It looks like you have an outside thread with inside sweat fitting.
  7. hj
    26,245
    Those are male hose faucets soldered to a copper line. The thread is part of the faucet so it will come off when you remove the faucet from the copper. You probably WILL want to solder female threaded adapters onto the copper then screw the new hose faucets into them.
  8. jim mills
    141
    nebraska
    It that's the case, why not just replace the packing?
  9. appdude
    appdude New Member
    36
    Ontario
    I think i'm understanding this now, The "threaded" piece is literately in the valve and can't be physically unscrewed. Also if that being the case then I will replace the packing. Cant I just get the new bonnet/packing from a new valve that is exactly the same?
  10. ImOld
    ImOld New Member
    73
    In the rumble seat
    This is a perfect example of what the average person cannot know.
    Plumbers will put together any pieces-parts that fit together regardles of whether these parts were intended to be used that way.
    It looks like you have a solid faucet intended to be threaded into a 3/4" fitting.
    It just so happens a 1/2" copper pipe will fit inside the threaded part and can be soldered there perfectly.
    Done all the time because it saves on carrying many more parts.
    Of course the picture is not detailed enough for me to be 100% sure, so...........................
    Carry on!
  11. appdude
    appdude New Member
    36
    Ontario
    il try to post a clearer picture but here is the valve i plan on taking the bonnet/packing/washers from
  12. Reach4
    Reach4 Active Member
    1,883
    To take a better picture, use a camera and put it into "macro" mode. That mode is often represented by a tulip icon. [​IMG] Shoot a side view.
  13. appdude
    appdude New Member
    36
    Ontario
    Okay here is a better pic, My camera is acting up badly
  14. Reach4
    1,883
    That confirms HJ, and I think ImOld is sure now too.
  15. DonL
    DonL Jack of all trades
    3,812
    Houston, TX
    That looks like one of those 1 fits all that is threaded on the inside and out.
  16. appdude
    appdude New Member
    36
    Ontario
    Yay the new valves came, now how do i remove the bonnets. They are literately impossible to remove.....if the new ones are like this, then i imagine what the old ones will be like....
  17. jim mills
    141
    nebraska
    Bet this guy could do it!
  18. DonL
    3,812
    Houston, TX
    Two wrenches should do it.
    Offset the wrenches by just a little and use both hands around both wrenches to line them up to break it loose.
    Good Luck.
  19. appdude
    appdude New Member
    36
    Ontario
    I do use those wrenches, both of em.
    Now another idea popped into my head. Sharkbites have always been my friend in when it came to plumbing. Now below i listed some things that came to me when i was reading through the posts.
    Now i was wondering if i could screw on my new valve and cut off the old ones with a tube cutter and push on the pipes.
    Here is a more visual example of what i mean
    PF-Male-Connector-300x240.jpg + m76.jpg = Push on shutoff valve
    Is this a good idea? Or should i stick to switching the stems. Another thing is the lack of space to cut the pipe. Can i still cut it?
  20. DonL
    3,812
    Houston, TX
    Have you tried Opening the old Valves all the way, then tightening the stem nut ?
    Sometimes that will make them stop leaking. If it is a stem leak.
Similar Threads: Need adivce
Plumbing Forum, Professional & DIY Advice, Tips & Need help with identifying the manufacturer of diverter spout Today at 10:09 AM
Plumbing Forum, Professional & DIY Advice, Tips & Looks like a delta 600 - but not - any ideas? need new valve Monday at 2:17 PM
Plumbing Forum, Professional & DIY Advice, Tips & Need a solution for my shop. Jul 12, 2014
Plumbing Forum, Professional & DIY Advice, Tips & need help identifying bath faucet Jul 2, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Need help identifying faucet/tap Jun 29, 2014
