Need a recommendation, water softener
Discussion in 'Water Softener Forum, problems, installation and r' started by harivney, Nov 2, 2013.
  1. harivney
    harivney New Member
    May 8, 2013
    Florida
    I am finally going to replace a 20+ year 9X48 autotrol 155 system (resin, green sand and potperm tank). I'm leaning towards Fleck 5600 and keeping green sand/potperm).
    Would you recommend a different system?
    Here is raw well water info:
    Raw well water:
    Ph - 7.4
    TDS - 200
    hardness - 85.5
    Iron - 1.0
    Iron - bacteria - not tested
    Manganese - nd (not detected)
    Copper - nd
    Nitrates - nd
    sulfides - pos (positive
    Tannins - nd
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Have you heard of Greensand Plus? Instead of using KMNO4 to regen the Greensand, the plus uses chlorine pellets. I would choose a Fleck 5600 over the Autotrol 155 amytime.
  4. harivney
    harivney New Member
    May 8, 2013
    Florida
    Mialynette - thanks for the reply. Did not know about greensand plus but will look into it. Can you point me to a website that has a diagram that shows greensand and chlorine pellet setup?
    I guess the potperm tank gets replaced with a chlorine pellet tank??
    Thanks again
  5. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    It is the same exact setup. Instead of using KMNO4 in the pot tank, Calcuim hypocloride pellets are used. The unit works best with a valve that can be set to a fill first.
Similar Threads: Need recommendation
Water Softener Forum, problems, installation and r Need Water Softener Recommendation Aug 15, 2011
Water Softener Forum, problems, installation and r Need to purchase a water softener on line but need recommendation where Aug 6, 2011
Water Softener Forum, problems, installation and r Recommendations needed to improve my water filtration system. Mar 20, 2011
Water Softener Forum, problems, installation and r I need flow switch recommendation Oct 27, 2009
Water Softener Forum, problems, installation and r Watersoftener - Help Needed To Decide Apr 30, 2016
