Need a plug for a basement floor drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mortimer, Mar 27, 2009.
  1. mortimer
    mortimer New Member
    Aug 1, 2006
    I have a cast iron drain in the basement floor that has a hole for running a snake down the line. The hole is a bit over 1-1/2" and not threaded. I'm thinking of using a cone made of rubber or cork to plug it when not needed. Any ideas on where to get or what the part is called?
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is that what we called a test plug?
  5. kingsotall
    Aug 17, 2008
    That's what I put in to google images to pull up that pic! :cool:
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    LOL I knew but could`nt think of the name untill I saw it.::D
  7. hj
    hole
    My question would be why, if it is really a cleanout point, DOESN'T it have a thread in it?
  8. mortimer
    mortimer New Member
    Aug 1, 2006
    The drain is 50 years old. It might have been threaded at one time. The normal water flow is below the clean out.
    Let me see if I can find a picture...
  9. mortimer
    mortimer New Member
    Aug 1, 2006
    That might work. The only issue I can think of would be the ears on the nut. Could replace it with a standard nut. Thanks!
  10. mortimer
    mortimer New Member
    Aug 1, 2006
    I haven't been able to find a good picture. It is called a floor drain with concealed cleanout. This picture is somewhat similar except: 1) Trap is about 30 feet to the right and 2) pipe continues to left of drain.
  11. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Here in Illinois it is pretty common for the clean out in a basement not to have threads in it, they install a expansion plug instead. They do make expansion plugs that are flush at the top so not to be a trip hazard. They also make a plug we call a "Dickie" plug also known as a cone plug has a rubber insert with coarse threads that inserts into the pipe and the plug which is cone shaped as it threads the tapper pushes the rubber against the wall for a tighter seal.
    http://www.missionrubber.com/Products/TConeStoppers.php
    [​IMG]
  12. mortimer
    mortimer New Member
    Aug 1, 2006
    Sweet. That was what I was looking for. Now to find someplace that sells them. Thank you.
  13. hj
    drain
    The concealed cleanout would be completely useless, and redundant, unless the trap was not only at the drain, but integral with it.
Similar Threads: Need plug
Plumbing Forum, Professional & DIY Advice Cleanout plug removal on cast iron help needed, 3.5" Oct 16, 2015
Plumbing Forum, Professional & DIY Advice Very plugged condensate line, need expert help. Jul 29, 2015
Plumbing Forum, Professional & DIY Advice Uncommon Tub Plug - Need help to remove it Jun 6, 2015
Plumbing Forum, Professional & DIY Advice Toilet plugging issue, need some advice on options Mar 7, 2013
Plumbing Forum, Professional & DIY Advice Need cleanout plug on septic line Apr 9, 2012
