Need 14" rough to match AM Std White
Discussion in 'Toilet Forum discussions' started by dbbarron, Jul 6, 2009.
  1. dbbarron
    dbbarron New Member
    Apr 15, 2009
    Massachusetts
    I am looking for a 14" rough toilet to match (does not need to be exact) an older (20yr) American Std white tub.
    This is a kids and guest bath, so performance needs to be good, looks are not as important. Cost should be kept reasonable, but not at the expense of performance.
    Kindly suggest recommendations.
    Regards,
    db
  2. dbbarron
    dbbarron New Member
    Apr 15, 2009
    Massachusetts
    I should mention that prior toilet was an older AS with 12" rough and the extra gap to the wall did not bother us - we will also be installing a cabinet above the toilet which will hide the gap even more. Thus, 12" would be ok if we had to....
  4. hj
    toilet
    Buy an American Standard 14" rough toilet, but actually almost ANY white toilet will be a close match so you will not see any difference. Especially if the lavatory is a cast iron one.
  5. Terry
    Aug 17, 2004
    Just pick up a 12" then.
    American Standard doesn't move the bowl back, only Toto lets you do that.
    Put in the 12" and the wall cabinet.
  6. dbbarron
    dbbarron New Member
    Apr 15, 2009
    Massachusetts
    Seems from this forum that the only true 14" toilet is the unifit Toto and that seems to get very expensive (only expensive skirted toilets have the option).
    This is a kids/guest bath, and the toilet is behind the door (not visible when you walk in).
    Thus, likely will pick up a 12" of decent quality/cost based on this forum recommendations and live with the gap with cabinet above. Space/room is not an issue in the toilet area.
Similar Threads: Need rough
Toilet Forum discussions Need Advice: 10-inch rough-in for small space Apr 23, 2016
Toilet Forum discussions need help with 10" rough-in toilett Sep 2, 2015
Toilet Forum discussions Need unusual toilet with 20" rough-in Oct 25, 2013
Toilet Forum discussions Did I get a 10" rough-in when I didn't need one? Oct 4, 2013
Toilet Forum discussions 11" rough in, need round front which will fit Toto washlet Jun 25, 2013
