NC, Greene Co: how far off ground does outdoor receptacle have to be...
itr674
NC
I'm getting ready to run wiring for five outdoor receptacle and am wondering how far off the ground they must be?
JWelectric
Electrical Contractor/Instructor
North Carolina
That all depends on how high you want them mounted. There is nothing that mandates how high.
It might be prudent to keep them out of the 'splash' zone (the area where rainfall splashes back up after running off the roof) and above the normal snow load (probably not a consideration in warmer states). Then, I don't like to have to lean over too far, either!
JWelectric
North Carolina
thanks, I think I will plan on 24" above mulch then...
18 to 24 inches is what just about everybody around here mounts them. Be sure to mount them so they aren’t easily broke off. I use a 4x4 post installed at least 24 to 36 inches deep to hold them in place.
Also remember that PVC boxes and pipe will fracture easily when cold. If using PVC I highly recommend using 80 instead of 40 and nothing smaller than ¾ inch for its strength.
mtne
Electrician
Denver, CO
www.advrider.com
There's no minimum height requirement for recepticals in residential applications. The only requirements are that for each dwelling at grade level there is one receptical accessible not more than 6.5" at the front and back of the dwelling.
