Navien Intake Air Problem
Discussion in 'Tankless Water Heater Forum' started by alinford, Sep 9, 2009.
  1. alinford
    alinford New Member
    Sep 9, 2009
    Utah
    I have a CR-240 that is having an air intake issue when I put on the cover. Without the cover, the unit works fine, but once the cover goes on, I get the error that means the system is not betting enough combustion air. There are only 2 45's and a 90 in the 30' run, so we do not have too many turns or too much length.
    Has this happened to anyone else?
  2. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    Blocked outdoor intake screen
    or
    No screen on it and animal crawled in and died inside intake pipe
    or
    Sagging pipe install holding water
    or
    Reversed vent piping
    or
    Blocked intake screen built into intake collar on heater, above premix burner fan
  4. suavecito1177
    suavecito1177 New Member
    Jan 7, 2010
    Denver, Co
    The Navien is a learning unit. If you take the door off and then turn it on, it will learn that environment. What I have done in the past is unplug the unit, make sure your dip switch settings are correct and the power switch inside the unit is on. Install the door and wait 10 minutes for the unit to completely drain power. Plug the unit in and hit the power button on the controller. If you have an A model with recirc and buffer tank and you have a V2.0 control board you will need to turn the recirc on at the controller, not just by dip switch. Should take care of any intake air issues. I live in Denver, Colorado and with our altitude we have run into these issues alot. Let me know if that helps.
  5. zl700
    Aug 26, 2009
    Western NY
    What exactly does the Navien learn and how?
  6. ronrca
    ronrca New Member
    Nov 6, 2008
    ?Edmondton, Alberta
    I have the same model and the same error message came up twice in the time we moved into our new house since Sept 09. Both times it was the internal intake filter was dirty. The manual shows how to access and clean the filter. Works fine after its clean.
Similar Threads: Navien Intake
Tankless Water Heater Forum Navien NPE horizontal venting pitch? Jan 30, 2017
Tankless Water Heater Forum Controling Navien NPE internal recirculation pump Dec 15, 2016
Tankless Water Heater Forum Navien cr-240A water heater problem Nov 15, 2016
Tankless Water Heater Forum Navien NR-210 Error Code 045 Mar 28, 2016
Tankless Water Heater Forum Navien CH-240 knock/bang noises Mar 12, 2016
