Navien 180 ASME GAS COMBO Boiler/Hotwater heater / Carriage house?
Discussion in 'Boiler Forum' started by pkboulos, Jun 25, 2013.
  1. pkboulos
    pkboulos New Member
    Jun 25, 2013
    New York
    All,
    i am renovating a lofted one bedroom space maybe 600 sq feet above 2nd floor of a carriage house. i want to purchase this unit but i am worried it may be "too big" for the space?
    i would use it for baseboard heat and hot water... would there be any downside if it was too big? it says min output BTU of 17,000k... I dont have a lot of knowledge about this and need some help.
    I need to use gas as a i dont have enough electric for baseboard heating, i like the idea of on demand because i dont know how often i will actually be using the space of it i may rent it or what.
    thank you
    Peter
  2. jadnashua
    Without a heat load analysis, you won't know what you actually need, but 17K is probably 2-3x more than you need except on the coldest day of the century (this is a guess). Keeping the unit hot 24/7 to provide hot water is also a waste. There probably isn't a boiler sold here small enough for maximum efficiency, but a mini-split system should be able to handle it fairly easily along with a gas WH.
Similar Threads: Navien ASME
Boiler Forum Navien CH210ASME- burner cuts out for an instant Sunday at 7:24 AM
Boiler Forum Navien Combi CH-240 ASME: either DHW or Baseboard Heat Feb 8, 2015
Boiler Forum Navien CH210 ASME LP sometimes ignores thermostat's call for heat Jan 27, 2015
Boiler Forum Navien CH-240 ASME NG Feb 22, 2014
Boiler Forum Need Help Tuning Navien CH-180 ASME Mod Con Combi Dec 12, 2013
