Natural Gas Questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by figs, May 17, 2008.
  1. figs
    figs New Member
    May 17, 2008
    Surprise, Arizona
    Project Location: Surprise, Arizona
    Gas Company: Southwest Gas
    About two years ago, I had a gas piping company install PE pipe for a fireplace and two fire pits. Currently, the gas pipe is stubbed up at the gas meter, at the fireplace, and at each fire pit. The stubs at the fireplace and fire pits have key valves attached. The stub at the gas meter is just capped off. The gas pipe was inspected, but I never called the gas company to hook it up to the gas meter as I was going to call them when the construction of the fireplace and fire pits was complete. Well, the project was delayed for numerous reasons and this summer I am planning on starting construction.:mad:
    So, my questions for the pros are...
    Will the gas company require a reinspection before hooking the new pipe to the gas meter since the inspection took place nearly two year ago?
    Am I okay to proceed since the project was on hold for nearly two years?
    Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You are asking a generic question expecting specific answers. Local regulations will apply, so you should call or drop by the gas company and find out what their requirements are. It's their ball park so they get to set the ground rules. Of course you have a choice. You can like it or not.:D
  4. jadnashua
    Where I live, a building permit is only good for a year, unless extended (with good reasons). But, it sounds like the rough-in was inspected. Best place to ask is the building department.
  5. hj
    gas
    Here, once the gas gets to the gas meter it is your responsibility to hire a plumber to connect it to the gas meter, the utility does not do it. Assuming the gas meter is unlocked and supplying gas to some functioning appliance, the plumber then turns the gas back on and lights any pilots.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Gas Gas Gas
    It is amazing how many answers can be found by a simple phone call or two
    go straight to the source call southwest gas they will tell you yes or no ! !
    this is controlled by the Federal gov. because of inter- state transport of gas ! !
    so the only opinion that counts is southwest gas :D
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    "this is controlled by the Federal gov. because of inter- state transport of gas",
    specifically, the Department of Transportation or DOT. They got the duty because the original gas and petroleum lines that traveled across state lines were placed on railroad right of ways and owned by subsidiaries of those railroads.
    Because the different jurisdictions I work in have different pressure requirements for testing buried polyethylene gas pipe, I took it upon myself to do a little research on the matter. I contacted the tech dept of one of the manufacturers of these products and asked them what is the proper test pressure. They referred me to a DOT paper that mandated all buried HDPE pipe be tested at 50 psi, not 10 psi (standard for screwed steel pipe) or 60 psi (standard for welded steel pipe).
  8. hj
    gas
    I didn't notice it was in Surprise. SW gas does not connect anything after the meter. You need a plumber to make the connection. What happens after that depends on whether the meter is locked or functioning.
Similar Threads: Natural Questions
Plumbing Forum, Professional & DIY Advice Run natural gas to kitchen island - details Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Adding gas range and outdoor grill. Do i need a new natural gas meter? Sep 7, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas leak outside of house May 13, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas Line Pressure Test Mar 22, 2016
Plumbing Forum, Professional & DIY Advice Water heater - natural gas - black iron rebuild with flexible CSST Feb 16, 2016
