Name these Totos
Discussion in 'Toilet Forum discussions' started by praycop, Nov 29, 2008.
  1. praycop
    praycop New Member
    Nov 29, 2008
    Please help me identify the model of these toilets. These are pics taken by Craigslist seller.
    Is there enough room to feed water supply line behind the toilet? If facing the toilet the supply is plumbed on the left, these toilets look like the supply is on the right, under tank. I have a 12" rough in. The seller wants $225 for both.
    thank you
    Rob
  2. Terry
    Aug 17, 2004
    The C874 is a Carlyle, MS874114S
    The C884 is a Carolina MS887114
    Looking at the front, the water supply would be on the left, at least 7" to the left of center.
    From the pictures I can't tell if you would be getting the bolt covers on the side of the bowl or the required Unifit adapter with the toilets.
  4. praycop
    praycop New Member
    Nov 29, 2008
    Dang your good!
  5. praycop
    praycop New Member
    Nov 29, 2008
    Terry,
    I think I scored big time for these two toilets ($250 for both). I picked them up last night. One of them needs basically all the guts for the inside and the Unifit adapters came with them but are used. I might just buy new ones. Do I buy the Korky with flapper parts or the "Fits Toto" valve and separate flapper?
    Thanks again Terry,
    Rob
  6. jimbo
    jimbo Plumber
    San Diego, CA
    Well, I don't know it that was such a great deal for two used toilets, but you will need a Toto flush valve and flapper, not generics. I don't know if Lavelle ( Korky ) makes a "will fit" but if you get an iffy flapper, you will have iffy performance.
  7. praycop
    praycop New Member
    Nov 29, 2008
    Jimbo...given the cost for new ones it seemed like a good buy, these were used for a year then stored in garage for several, oh well, there mine now. Korky does make one but their website doesn't have a shopping side to it. I went to HD, ACE, and LOWES but they don't carry the Toto version.
  8. Terry
    Aug 17, 2004
    Korky has the quietfill valve that will work on the Toto.
    The original Toto by Korky has a bit more supply for the bowl fill.
    That's why I suggest repair and not replacement. The repair cap is $2.50 at Lowes. Lowes, at least around here also carries the 3" Korky flapper for Toto. Around $9.99
    There is nothing wrong with a used Unifit adapter. Just clean them up and reuse.
    Jimbo,
    I sell the Carlyle for $518 and the Carolina for a little more.
  9. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Anyone know which one this is?
    This is the Toto in one of my bathrooms. Came with the house when I bought it 6 years ago - don't know the model of it but would like to figure out what the MaP would have been for this toilet (model may not have been around for the initial MaP testing) in comparison to the Toto Eco Drake elongated that I've ordered.
    Anyone know what model Toto this is? All I see is a label on one side saying that this is a 1.6GPF qualified toilet.
    TIA,
    Dave
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  10. Probedude
    Nov 25, 2008
    CA
    Thanks Terry!
  11. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
  12. Probedude
    Nov 25, 2008
    CA
    I think you're right Peanut. I saw the different lip at the base but thought that maybe there's a few different Promenade models or that it was changed recently vs mine which is at least 6-7 years old.
    550 Map though, that's good! Explains why it's been troublefree these past 6 years I've had it. It was only because of this unit's troublefree operation that I was searching for another Toto (just got the Eco Drake).
    I remember the first time I looked at it I thought "Toto, now that's a silly name" then went off and found that they're quite respected and desireable.
Similar Threads: Name Totos
Toilet Forum discussions Polyseamseal, and current product names Mar 10, 2016
Toilet Forum discussions Anyone have a good or bad experience with GSI, sold by Nameek's? May 2, 2015
Toilet Forum discussions Wrench for flush valve seat? not sure of name. May 4, 2010
Toilet Forum discussions Cast Iron Porcelian Enameled Toilet Bowl?? Mar 22, 2009
Toilet Forum discussions no name Aug 31, 2005
