Mystified in Chicago (Pipe Noise)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by watts28, Apr 21, 2005.
  1. watts28
    watts28 New Member
    Apr 21, 2005
    Can anyone help me with this strange question?
    In the past 5 weeks I have noticed a pipe "banging" sound (not exceptionally loud) once water is running within the house. I would say it takes 2 - 3 minutes to start and continues with a "bang" every minute or so. If the water in the house is shut off, the "banging" will continue at the same rate for about 10 minutes. I've heard water hammer before, but why would it continue for so long after everything is shutoff? I shutoff water to the house and allowed the system to vent, but this did not eliminate the issue.
    Does this sound like a drain issue or a supply issue? If its drain related, should I attempt to see if the vent stack has an obstruction?
    Thanks for your help.
  2. hj
    "Water hammer" does not occur while you are running the water. It occurs when you shut the faucet off too quickly, and even then it is a momentary thing. Under certain specific conditions you can get water hammer when you open a faucet too quickly, but it is a rare situation and requires very specific parameters for it to occur. In either case the hammer only occurs for a fraction of a second and then disappears. You have some other condition, but without being there to hear it and test all the possible causes we cannot help you solve it.
  4. watts28
    watts28 New Member
    Apr 21, 2005
    Thanks hj
    Thanks for your input. This seems quite unusual. I plan to shut off my water supply and then pour water down my drain to see if the noise still occurs. Perhaps this will tell me if it is supply line related or not.
    After that, its a call to the plumbing authorities!
  5. jadnashua
    Does this happen when running cold water, or only when running hot? If hot, it could just be either the supply line or the drain expanding. Then, after you stop, as it cools, it contracts. If the pipe(s) in question have a tight fit through a wall, floor, or stud in any way, that could be it. Actually, it doesn't necessarily have to be rubbing on something, it could just be expanding/contracting, but it usually makes more if it is rubbing on something. My unprofessional opinion.
  6. watts28
    watts28 New Member
    Apr 21, 2005
    Thanks jadnashua
    jadnashua -
    That's a great point! Thermal expansion sounds like it could be it since it continues for awhile after shutoff. I'll check out the hot / cold question.
    I appreciate your help.
Similar Threads: Mystified Chicago
Plumbing Forum, Professional & DIY Advice Chicago Quaturn Faucet Problem Mar 24, 2015
Plumbing Forum, Professional & DIY Advice Looking for plumber in Chicago with ejector pit experience Mar 27, 2014
Plumbing Forum, Professional & DIY Advice Chicago faucet tool Jul 30, 2012
Plumbing Forum, Professional & DIY Advice Yet another washer stand-pipe question for Chicago Feb 20, 2012
Plumbing Forum, Professional & DIY Advice Chicago Angle Stops Sep 19, 2011
