Myers pumps? Rustler or Predator, what is the difference between the two?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by project_x, Aug 30, 2010.
  1. project_x
    project_x New Member
    May 23, 2008
    Hi all,
    I am looking at these pumps, what is the difference between the two models? They look to be roughly the same price and specs....
    Thanks,
    Rob
  2. ballvalve
    Dec 28, 2009
    northfork, california
    As I recall, one has a poly outlet and the other has a stainless steel outlet head and check valve. I have older rustlers with cast iron outlet heads. They both likely do the same job for the same amount of life span. Go to the Myers site and see the PDF files on the pumps specs..
Similar Threads: Myers pumps
Pumps and Tanks Well Forum & Blog. Water is life. Replacing submersible - Aermotor, Franklin, Myers, Sta-Rite? PVC or metal drop pipe? May 6, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation System well set up - Myers HJ100D Apr 20, 2012
Pumps and Tanks Well Forum & Blog. Water is life. No prime, Myers Pump Jul 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Can a Myers deep well pump be used as a shallow well pump? Jun 25, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Myers Hydropneumatic Pump Tank not kicking on Jun 5, 2010
