my well isnt acting right
Discussion in 'Pumps and Tanks Well Forum & Blog' started by menzerick, Aug 18, 2013.
  1. menzerick
    menzerick New Member
    Aug 18, 2013
    oregon
    so my well is down 315' I have a 2500 gal holding tank and everything is set up pretty normal. i also have a pressure tank and a secondary pump, and a pump saver wired in. the well pump is 1 1/2 hp.it only pumps water into the holding tank for about 5 seconds and stops. if I let it sit for about a half an hour with the pump and pump saver turned off, it pumps for about a minute and shuts off. shouldnt it just keep pumping until my holding tank says its full and shut off. i don't know if the pump saver is detecting too much load and telling it to shut off, or im running out of water, or the pump is bad. i don't care if it pumps only a couple gallons a minute just as long as it keeps pumping. a couple seconds at a time just doesn't seem right. any input would be great.
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    You need to start by checking the amp draw on the pump and the static level of the water in the well.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Bypass the pump saver, go direct to the pump, see if the pump will continue to run. If not, electrical if it quits either you are pumping the well down or the pump is bad
  5. menzerick
    Aug 18, 2013
    oregon
    Kinda the direction I was thinking.thank you
Similar Threads: isnt acting
Pumps and Tanks Well Forum & Blog UV disinfection isnt working Apr 7, 2013
Pumps and Tanks Well Forum & Blog Deep Water Well Advice Before Contracting Apr 9, 2011
Pumps and Tanks Well Forum & Blog Well acting funny. Oct 13, 2010
Pumps and Tanks Well Forum & Blog Water pump is acting very odd...? Nov 12, 2009
