My water pump circut breaker
Discussion in 'Electrical Forum discussion & Blog' started by ksandypt, Feb 26, 2008.
  1. ksandypt
    ksandypt New Member
    Feb 26, 2008
    The water pump circuit breaker keeps going off as soon as I reset it. Is this electrical or is it an issue with the pump? Is there anything I can do or should I call electrician or plumber?
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Considering the pump is probably at fault I would start with a plumber.
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Turn off the power and disonnect/cap off the wiring at the pump.
    Turn the breaker back on.
    If it still trips, it's the wiring. If it clears, it's the pump.
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    But the pump is 300' down. :eek: :D
    (Hey, you did say AT the pump. ;) )
    Seriously, I agree, go to the pressure switch and disconnect the load wires (to the pump). If it clears, call a plumber. If it still trips, call an electrician.
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Disconnect the wires from the pressure switch and do the breaker test again as suggested and described above. Then, using your multimeter (homeowners should own one) measure the winding resistance of the motor and the resistance between the wires to the pump and ground. The answer will tell you if the fault is in the wiring down the well or the pump, but may not tell you which it is.
    If there is a short circuit or a short to ground then you have a down-hole problem which means that you should call a well service man, unless you are an agressive DIYer.
Similar Threads: water pump
Electrical Forum discussion & Blog Water pump will no longer work off generator. Jul 31, 2015
Electrical Forum discussion & Blog Electrical cost to pump water? Apr 7, 2015
Electrical Forum discussion & Blog Conduit Underground from House to Garage (+water) Sep 29, 2016
Electrical Forum discussion & Blog Dedicated electrical box (for hot water tank) needs replacing: what to expect? Dec 14, 2015
Electrical Forum discussion & Blog Water pipe grounding Aug 13, 2015
