My pump cycles on & off as soon as you turn on the h2o
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lucy7127, Sep 12, 2005.
  1. lucy7127
    lucy7127 New Member
    Sep 12, 2005
    I have always had bad water pressure but things have become worse. I was told to try pumping air in my Champion prepressure tank. After doing this my water pressure is even worse (eg. if shower is running I can't get any water anywhere else in the house!). In addition the tank is turning on and off continually while the water is on. The gauge moves back and forth between 30 & 60 psi. PLEASE HELP! :eek:
  2. hj
    air
    Too much air will cause the same problems as too little air in the tank. Without checking the precharge when the system is completely drained, you have no idea whether to add air or let it out. But from your description, you may have to let some out. CHECK IT FIRST before doing anything else.
  4. lucy7127
    lucy7127 New Member
    Sep 12, 2005
    Is it hard to completely drain and then start over? If not how would I go about doing this?
Similar Threads: pump cycles
Plumbing Forum, Professional & DIY Advice Hydromatic HPUSP125 bad switch? Brand new pump cycles on/off when sink is full Aug 7, 2013
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Home run w/PEX how about a heat circulating pump? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Turning on well pump at breaker box Jan 30, 2017
