My latest problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Rydog79, May 29, 2012.
  1. Rydog79
    Rydog79 New Member
    May 29, 2012
    Chattaroy, Wa
    Hello everyone,
    First time posting here but not my first time to the site. Got some very useful info from here in the past. So I feel I must say thank you. :)
    I'm no expert but I have gained a decent amount of experience over the last 10 years. Replaced many parts and help diagnose quite a few problems for myself as well as neighbors. I have a new problem that has me stumped though. I'll start with what my system consists of:
    200' well
    1hp submersible
    Franklin Electric 1hp control box
    2 - 32 gallon pressure tanks
    Square D 30-50 pressure switch (I adjusted this a few years back to be roughly 40-60)
    Well the the first signs of a problem started a couple months ago and has slowly gotten worse. When the pump cycles on there is about a 3 second delay with no water at all. It started as only about a 1/2 second of time with no water. So I finally got some time to inspect the system today. I figured maybe the pressure switch wasn't engaging until a very low pressure or maybe even zero. I let the water run and watched the gauge closely. At about 38 psi instantly the flow stops and needle falls to zero. I hear the pressure switch click on and about 3 seconds later the gauge comes back up to 30 or so and I have water again. So I let it cycle and watch again. The pump kicks off at about 65. Needle slowly drops to 38, the water stops and the needle drops to zero. I then shut the faucet off and let the pump build pressure and kick off. I shut the power off and then tried again. Same result as the first couple off times. Where is this 38psi of pressure going so fast?
    Pressure switch seems to be working fine. Pressure gauge is new. Pump was replaced a couple years ago. Control box is fairly new.
    Maybe the check valve is bad in the pump or maybe I have a leak somewhere. I let the system build pressure and let it sit for half an hour. It held just fine.
    Any ideas?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The air pressure in the bladder should be 2 - 5 PSI less than the kick-in pressure setting on the switch. You have too much air for the kick-in setting. Either increase the kick-in or reduce the air precharge.
    Perhaps your air pressure gauge and your water pressure gauges are not reading the same.
  4. Rydog79
    Rydog79 New Member
    May 29, 2012
    Chattaroy, Wa
    Very good thought. I'll try a different air gauge. The one I'm using is not very good. Thank you.
  5. Rydog79
    Rydog79 New Member
    May 29, 2012
    Chattaroy, Wa
    Yep that was the problem. Tanks were actually 2 or 3 pounds higher than cut-in. Adjusted switch to 40 and tanks to about 37 and everything is perfect. Thanks LLigetfa. Moral of the story: always use quality tools :rolleyes:
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    You're welcome. It comes up often enough that I've been nagging valveman to put it in a sticky.
Similar Threads: latest problem
Pumps and Tanks Well Forum & Blog. Water is life. Remote cabin water problem Saturday at 12:53 PM
Pumps and Tanks Well Forum & Blog. Water is life. Houston, we have a problem. Well sunk? Jan 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well problems - need help! Dec 6, 2016
