My boiler regularly needs refilling.
Discussion in 'Boiler Forum' started by CG, Feb 4, 2009.
  1. CG
    CG New Member
    Feb 2, 2009
    My mum had central heating installed a couple of years ago but the system always seems to need refilling regularly, every couple of weeks or so. I can't see any signs of a leak anywhere so I don't really know what is going on. How often should the system need refilling?
    The installer didn't give us any information about how to work the system. In fact, my mum received a government grant to have the heating installed and it was condemned before we switched it on - because the installers didn't attach a flue!! :eek:
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    You will probably need to top it up 1 time per year. Any more than that, its a leak.
    It could be inside the walls, near a valve, T&P valve, (Under floor piping . This probably doesn't apply to you). Could also be leaking slightly in the boiler (this water would boil quickly and evaporate without any signs of water being there.)
  4. jadnashua
    Eventually, there will likely be a mineral deposit buildup where it is leaking, and it may be easier to find.
  5. CG
    CG New Member
    Feb 2, 2009
    Thanks everybody! It looks like I have got a leak somewhere then! I thought I might have.... I will go on a leak hunt at the weekend! ;)
  6. Ian Gills
    Jul 24, 2007
    USA
    It's probably a leak and one of the first places to look for it is where you top it up. Some models have a check valve to add water to the system and this can weep.
Similar Threads: boiler regularly
Boiler Forum Weil McClain cga6pidn boiler Mar 17, 2017
Boiler Forum An American Standard Gas boiler Mar 13, 2017
Boiler Forum Boiler slowly fills Mar 7, 2017
Boiler Forum Should I replace ~70-year-old boiler? Mar 5, 2017
Boiler Forum Boiler Water Temperature Calculation Mar 2, 2017
