My bathroom remodel, WC venting and waste prevension plan
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Fubar411, Nov 15, 2007.
  1. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Okay, I've been watching this forum for awhile, and many questions have been answered. I haven't seen my particular question. I am doing a bathroom with laundry in my house. I get a little confused with the venting requirements on the toilet and how to connect it into the waste. The sink and laundry drain and venting, I get. I'm doing those based on a lot of post reading. However, because I don't want to cut into my nice 10x2 joists, I was hoping to not have to vent the toilet. It is within 6' of the venting, as this is a small room. But would I have to worry about the solid waste causing a problem as I enter the main stack?
    Attached is a pretty crude drawing, the sink and laundry are vented/drained properly. I'm just concerned with how the toilet joins up and is vented. The whole room is 7' x 10'
    Thank you so much!
    -Rob
  2. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Oh, since someone will ask, this is in Missouri.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    is that a top view? it looks a bit like both a side view and a top view.
    what fittings are you using? Tee-Wye, San-Tee, long sweep, etc.
    david
  5. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    It is a little of both. I don't have the fancy software and I stink at drawing.
    For the WC, it will be a 3" long sweep headed downward. The washing and sink will be a 2" long sweep and will be vented.
    The part I'm having confusion on is where the toilet, sink, and washing machine drain meet. Both the sink and washing drain are vented, I'm hoping to get away with not venting the toilet.
    I'm now thinking it might be best of I have a + shaped 3" fitting with two 2" sanitarys coming into it from the sides.
  6. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Want some? It's free from the good folks at Google, and real easy to learn:
    http://www.sketchup.com/
    If you've been lurking, then you've seen Nelson's posts - it's what he's been using.
  7. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    So I was stuck in traffic for an hour, and this is what I came up with. The part I wonder if I'm okay is in yellow
  8. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    I have seen Nelson's posts. Pretty cool 3d stuff. I don't know if I have enough time to learn the software.
    I called a plumber today to ask if I could buy an hour of his time to show him what I wanted to do. Haven't heard back yet...is that an odd request?
  9. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    I changed my image above. I have to get started tomorrow, does it look okay the way I have my waste coming together and not having my toilet vented?
  10. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    No. I wouldn't claim it or expect it to work. I don't know what the codes are like in Missouri, but here you'd be told to rip it out and start over.
    You have to vent the toilet. I'm unclear as to why you don't want to drill a 2" x 10," or why you don't want to vent the toilet.
  11. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Good point, just laziness on my part I guess. I had read that toilets didn't need as much venting since it was so close to the main stack.
    Can I vent with a 2" pipe if the drain is 3"? Would I just have a 2" coming up off the 3" drain?
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Yes pull a 2" vent for the toilet
  13. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    So I'm okay with the 3x3x2x2 wye sanitary +?
    I think this will work, I'll post real pictures as I go, since this is pretty simple.
  14. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    okay, here is the dry fit for the interesting part... Do I have the right fitting (going the right way?) for venting the toilet? All I could find was a sanitary fitting.
  15. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    do not use a tee wye like that it must be turned or be wrong
  16. hj
    vent
    The tee is wrong, and the sanitary cross will not approved in the majority of areas.
  17. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    I turned the T, so the "gas flows up".
    What is wrong with the cross? It is just before it hits the main stack. My main is cast iron and someone already linked the 3" PVC into it, and I'd prefer not to have to bust into it for a second connection.
  18. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Would I be better off with the cross that looks more like a Y with the wastes coming in?
  19. jimbo
    jimbo Plumber
    That's a good one! Don't know who told you that!
    This project is an excellent example of the old proverb..." the devil is in the details". You have laid out a bathroom drain system which seems to make sense. Unfortunately, you failed to consult a plumbing code book. The size of piping is incorrect for a wet vent, the fittings are wrong, etc. A sanititary tee cannot be used on its side. A sanitary cross usually is not accepted in the usage shown. You would probably have to increase all the pipes to 3". Etc.
  20. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    If plumbing code books are written anything like the NEC, nobody would ever be able to change a light bulb.
    Would a cross with the Y type arms be acceptable? I did know that the sanitary shouldn't be on its back, but how else could I vent the toilet?
  21. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Ok, new plan. How does it look to you guys?
    Just noticed I have the toilet vent going the wrong way, but otherwise?
Similar Threads: bathroom remodel
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Pending bathroom remodel, asking first Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Remodel cover plate for deck mounted bathroom faucets Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbing Remodeled Bathroom Dec 21, 2016
Plumbing Forum, Professional & DIY Advice 1st post - having bathroom remodeled. Need plumbing help Nov 21, 2016
