heathergeorge
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Hi! I've just purchased a 32X32" fiberglass shower base, manufactured by Mustee. The base has a built in drain, that connects to the pipe by a rubber seal.
I have some questions/concerns regarding this seal...has anybody ever used this product..? The directions indicate that you should just lubricate the rubber seal with liquid soap, then tamp it into the drain.
My concern is that this will not be a water tight seal, and will cause leaking. Is there an alternate/better way to fix this drain to the pipe..? If not...is there some kind of trick to getting the rubber seal installed..? I followed the directions, but I hammered away for nearly an hour, and still can't get the seal to go down flush with the top of the waste pipe.
Thank you!!
Thank you!!
