Multiple shower head supply volume question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Photovor, Jan 11, 2010.
  1. Photovor
    Photovor New Member
    Jul 3, 2006
    Hi, I was hoping that someone could give me some advice on some plumbing for a new shower I'm working on.
    We're planning on having 2 (High-Efficiency) shower heads plus a rain maker shower head as well. Each shower head will be controlled by their own mixing valve, and off of one we'll have a diverter for the rain maker.
    The supply to the house is 3/4 inch, and that's continued into the water heater and back out, so I do have 3/4 lines I can tap off of, but I was planning on using 1/2" pex for the entire shower. Am I going to have a flow issue with only using 1/2" or should I just do everything in 3/4"? Should I do 1/2" and do a pressure balance loop between the valves? Please advise :)
  2. jadnashua
    The real question is how many heads will be running at the same time. If all of them, you'll probably be disappointed running it in pex, especially if you use 1/2" which has a smaller ID than 1/2" copper. Once you know the max flow, check it against the valve you want to use. 1/2" valve can flow about 5gpm with 1/2" copper supplies. A 3/4" valve can probably flow over twice that. Depending on the heads, you may not need it, but I think I'd run the 3/4" up to the valve, and if you don't go to a 3/4" valve, reduce to 1/2" there.
  4. Photovor
    Photovor New Member
    Jul 3, 2006
    That's what I figured. I know pex is smaller id than copper, especially when you get into using the crimp fittings as well.
    At least 2 shower heads would be running at one time, but probably not all 3.
  5. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    The flowrates are critical to sizing as mentioned by Jim earlier. However, even if the "high efficiency" means 1.5 gpm or so, you should probably size if for the 2.5 gpm rating of standard modern showerheads. In that case the total maximum flow would be 7.5 gpm.
Similar Threads: Multiple shower
Plumbing Forum, Professional & DIY Advice Multiple fixtures on 2" pipe Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Single valve for multiple outside hose bibs Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Multiple types of sewer smells? Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Natural gas and multiple appliances Nov 4, 2014
Plumbing Forum, Professional & DIY Advice Multiple issues in bathroom renovation Aug 9, 2014
