Multi-head showers
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Fubar411, Mar 2, 2011.
  1. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    I'm installing a multi-head shower at my sister's this weekend, marketing says it is a vertical spa. The install directions are pretty specific about balancing loops and placement. I've read on here that the loops aren't always necessary, but it isn't that much more work at this point. Moving on, two questions:
    - Am I just safer using 3/4" for everything, even though the heads are all 1/2"
    - Can I use threaded copper female in the wall and then brass stub outs, or am I safer just using the bronze drop elbows (excuse if I have it named wrong).
    Thanks again for an excellent forum.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    should go with the balancing loops. 1/2" is probably going to be fine and use the drop ells
  4. jadnashua
    What is the maximum flow of the system? 1/2" copper can flow about 5-6gpm, and a 1/2" valve and supply lines may not be able to supply what you need or want. You'll also need a pretty substantial WH and might look into a waste drain heat recovery system.
  5. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    The specs demand/call for 3/4" supply, which I've done, doing the rest in 3/4" isn't difficult. I will use the drop ells as well.
    The water heater is a 50gal electric that is on its last leg. I'm thinking the AO Smith Vertex...man that looks like a sweet machine.
Similar Threads: Multi-head showers
Plumbing Forum, Professional & DIY Advice Building a new multi-head shower Aug 23, 2015
Plumbing Forum, Professional & DIY Advice ONLY showers not hot Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Two walk-in showers suggestion on how to do this Apr 24, 2016
Plumbing Forum, Professional & DIY Advice B2B showers w/ extreme pressure variations Oct 2, 2015
Plumbing Forum, Professional & DIY Advice Supply Lines to Separate Showers Apr 3, 2011
