Moving Water Meter from Horizontal to Vertical Position
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jluksic, Aug 12, 2008.
  1. jluksic
    jluksic New Member
    Jul 29, 2005
    Colorado
    on well water... rearranging furnance area and need to re-position the water meter from a horizontal position (neer floor) to vertical position (parallel to wall)... any potential problems with the water meter being in a vertical position...?
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    You will want the meter in the horizontal position. Look for the size of the meter and spread and see if you can purchase a Meter Horn from a local (Plumbing supply store) Meters are labled 1-4. Make sure you put a full flow ball valve before and after meter.
  4. jluksic
    jluksic New Member
    Jul 29, 2005
    Colorado
    plan to use same water meter... but why must it be in a horizontal position?
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Only problem is that most manufacturers don't certify the accuracy of meter in the vertical flow position. If some water utility is collecting money based on the meter they won't want you changing it, which usually involves breaking the seal.
    There is an assembly called a "meter horn" or "meter resetter" that allows the meter to be installed horizontally in a vertical pipe run. Most utilities have them or you can buy one from USABLUEBOOK. https://usabluebook-onramp.com/cgi-...gm=unixgrep.bbx&itemdesc=meter+resetter&class=
    There is also one called a meter insetter.
Similar Threads: Moving Water
Pumps and Tanks Well Forum & Blog. Water is life. Can't get water to the cabin after moving fresh water tank under the cabin. Sep 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. moving well water line May 16, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Rusty Water after moving Point Feb 22, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Removing sand from 32' dug well Jan 13, 2017
