Moving toilet drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TrevorO, Jan 12, 2009.
  1. TrevorO
    TrevorO New Member
    Jan 12, 2009
    I would like to move my toilet in my second floor bathroom so it is in the opposite corner of the current location. My problem is I don't know if it's even possible because I would have to go through 5-6 joists. My home is 100+ years old with 2x8 joists. I do have the option (if it even helps) if I can go through the joists to have the holes be over top of the sill plate (I think that's the right term) that is sitting on a block wall.
    If someone could let me know if this can be done or if I'm totally out to lunch it would be great. I would most likely get a plumber in to do the job if it can be done.
    Thanks
  2. TrevorO
    TrevorO New Member
    Jan 12, 2009
    Edit to the above
    It would only be 4 or 5 joists
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    A plumber on-site would be the best solution.
    To little information for us to say anything here.
  5. zxed
    zxed New Member
    Dec 7, 2008
    California
    from my current project....
    you would need to know how much room you have below the 2x8 joists.. and if the ceiling joists are going to be in the way...
    also., you will need to vent the trap at the new location., you would need to know if you are moving closer or further away from the wastepipe in the bath :)
Similar Threads: Moving toilet
Plumbing Forum, Professional & DIY Advice Moving toilet location and venting Mar 6, 2016
Plumbing Forum, Professional & DIY Advice Moving Toilet, Adding Shower To Toilet Drain Line - Please Check Diagram Nov 28, 2015
Plumbing Forum, Professional & DIY Advice Moving an upstairs toilet in a 1926 house... Oct 9, 2015
Plumbing Forum, Professional & DIY Advice Moving toilet in house built in 1962 - help with 90 degree w/ low heel. Apr 10, 2015
Plumbing Forum, Professional & DIY Advice Moving toilet Dec 30, 2014
