Moving toilet 4 to 6 inches to the side?
Discussion in 'Toilet Forum discussions' started by MOV, Jan 31, 2006.
  1. MOV
    MOV New Member
    Dec 5, 2005
    Indiana
    Well, crap. We've run into another issue with a new Drake toilet. There is a 4" PVC pipe extending from ceiling to floor right next to the existing toilet. It's about half an inch from the left side of the toilet tank. Normally not a big deal, except the existing tank is only 16" wide. :eek:
    Save for some $450+ one-piece or special order (which are out of the question), every single toilet we can find -- including the Toto Drake we were ordering -- has a tank that's 18" to 20" wide.
    And at least on the Drake, the flush handle is also on the left, extending it even a little further.
    So given we need probably 4" of clearance to fit a new Drake, is there any good/easy way to move a toilet several inches (4-6") to the right?
    Here's a couple photos of our setup. Thanks! :)
  2. jadnashua
    What is the floor made of? Break up the concrete, move the drain over where you want it, put it back together...
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Check the Caroma Caravell toilets. They have push button for flushing on the lid and may be narrow enough.
    They are my favorite.
    Their 4" trapway will flush anything you can throw at them.
    The Caroma Tasman is the basicly the same toilet only with a plastic tank and less $$$
  5. jk60
    jk60 Engineer
    Nov 20, 2005
    Engineer
    San Francisco
    The tank portion of the one piece Toto Ultramax is about 16" long at it's widest point and it tapers down to 14" at the top of the tank. Should work for you.
      File size:
      18.8 KB
      1,696
  6. hj
    toilet
    There is no easy way to move it, but moving it 4"-6" is often easier than moving it 1" or 2". Also, unless that bathroom does not have any walls around it the water heater is not permitted in the bathroom.
  7. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    what's in that pipe? Looks to me like you could reroute it to the back of the toilet with some 45's and just get it out of the way.
  8. MOV
    MOV New Member
    Dec 5, 2005
    Indiana
    Thanks for the replies. To address the individual suggestions:
    - We're assuming the floor is tiled over concrete, but as a couple who knows NOTHING about plumbing, digging into the concrete and messing with the underground plumbing is hopefully a last resort. ;)
    - Thanks for the tips on the Ultramax and the Caroma. Only problem is the price. ~$400 almost doubles what we were ordering the Drake for. We'd have to see if the budget would allow it. (Although, if most of our other options would exceed $200 anyway, we may as well just go for the expensive toilet instead of the cheaper one plus plumbing work). Hmmm....
    - To be specific about the room, it's actually a utility room that the previous owners added a sink and toilet to. It used to be a bare-studded room for the washer, dryer, heater, water heater, etc. It was then drywalled over (and horrifyingly wallpapered, as you can see from the pics -- we've since torn it down and are in the process of spackling and painting), and they plopped a toilet in the middle of the room and stuck a sink next to the washer. For reference, how does that work with the location of the water heater in the room? We were unaware of any issues.... :eek:
    - We're not positive what's in the pipe (RRW, I assume you're talking about the PVC to the left of the toilet?) but we're guessing it's just drainage from the upstairs plumbing. Would we just saw it apart at the top and bottom and insert angles to maneuver it behind the tank before coming back to go into the ground?
    Sorry, probably sounds like a dumb question, but maybe I can learn a little about plumbing along the way. :)
  9. hj
    heaters
    Water heaters, or any other open flames, are not permitted in bathrooms or bedrooms, because of the potential for carbon monoxide fumes in a small, or sleeping area.
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    What you are doing is dangerous and illegal. It will probably be easier to relocate the water heater than the toilet, but you can't have both in the same room.
  11. MOV
    MOV New Member
    Dec 5, 2005
    Indiana
    Hmm... it's a 33-year-old house and we had it inspected by a licensed Home Inspector before we bought it. In the last 4 months of examining and purchasing this home, no one has ever said anything about having a toilet in the utility room. :confused:
    It probably doesn't make a difference, but like I said, it's not a main bathroom with a water heater in it.... it's a utility room that the previous owners stuck an extra toilet in for convenience. Not sure why no one (since they did it probably 8 years ago, up through us buying it) has pointed that out as an issue.
  12. PA
    PA New Member
    Feb 2, 2006
    Coral Springs, Florida
    Toilet
    The TOTO Aquia is 15 3/4 inches wide at the widest point and Terry lists his price at 295 in white, that's about 66 more than the Drake EL and I think it looks :cool:
  13. parrishnut
    parrishnut New Member
    Jan 22, 2006
    I'm not a plumber.. but
    when the washer goes, get a stacing unit, I have one they are fine use less water, and it will give you more room to upgrade the sink.. to something nicer.
  14. MOV
    MOV New Member
    Dec 5, 2005
    Indiana
    Well, for the size I need (and in the price range I can afford), I see a few Toto toilets:
    - Ultimate
    - Supreme
    - Aquia
    Is there anything I should know -- like good or bad reviews -- for any of these? Or am I pretty safe with any Toto toilet?
    I know the Drake and the UltraMax are considered "homeowner favorites", but due to size and money, respectively, we won't be able to get either of those. So how do the Ultimate, Supreme, and Aquia stack up in comparison?
Similar Threads: Moving toilet
Toilet Forum discussions PICK UP STIX, A tool for moving and picking up toilets Jul 12, 2016
Toilet Forum discussions Moving toilet pipes Feb 15, 2015
Toilet Forum discussions Need help moving toilet Feb 19, 2014
Toilet Forum discussions Is there a way to replace closet bolt without removing the toilet? Dec 26, 2013
Toilet Forum discussions Moving toilet 1-2 inches Aug 23, 2013
