Moving toilet 1-2 inches
Discussion in 'Toilet Forum discussions' started by Nlminio, Aug 23, 2013.
  1. Nlminio
    Nlminio New Member
    Aug 23, 2013
    Nj
    I have a toilet installed and I just put up the bathroom door and realized that the door is just shy of clearing the toilet by about an inch. Is there any way to simple move te toilet over a little bit so the door will clear?
  2. jadnashua
    Generally, no. It may not be hard, but it would involve either access from below or tearing out part of the floor to move the drain pipe. A design consideration might be to replace the door with a pocket door, then there's no swing to deal with. Or, a surface sliding door.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Swinging doors are a real space waster in a small bathroom. I faced this problem many years ago and solved it with a pocket door. When I added a bathroom in my basement, I did not want to use much space and it was a pocket door to the rescue again. This would be a very wise alternative to moving the drain.
  5. Terry
    Aug 17, 2004
    Is there space behind the bowl now that can be used?
    If so, then you may be able to move the drain.
    If you have a 4" drain, then you can fudge it back some.
    Though it may be easier to find a shorter in length toilet too if you have to move the entire drain.
  6. hj
    There could be several possibilities but we would actually have to see it determine which, if any, would work for you.
  7. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Is the toilet elongated by any chance?
    If it is, consider changing it to a round toilet.
Similar Threads: Moving toilet
Toilet Forum discussions PICK UP STIX, A tool for moving and picking up toilets Jul 12, 2016
Toilet Forum discussions Moving toilet pipes Feb 15, 2015
Toilet Forum discussions Need help moving toilet Feb 19, 2014
Toilet Forum discussions Is there a way to replace closet bolt without removing the toilet? Dec 26, 2013
Toilet Forum discussions Moving toilet 3 inches if easy access? Mar 16, 2013
