Moving Radiant Heat Pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nelsonba, Nov 25, 2008.
  1. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    I'm in the middle of a basement remodel. Right now I have radiant heat running to cast iron radiators (closed water system, not steam). In the basement I had to build a soffit around the main supply runs for the radiant heat system. These are large pipes and they hang down quite a bit from the ceiling and they are right in the middle of the room. The soffit ended up looking much more intrusive than I had planned. I'm wondering if it's possible to redo the main supply and return lines possibly with pex so that the ceiling could be finished off flat. If so would the pex need to be connected at each radiator or could you just tie on to the old pipes that connect to the main supply and do some type of manifold system by the boiler? I have 5 radiators on my main floor, 3 on the 2nd floor, and 1 in the basement. The ceiling is open in the basement so everything is accessible. I would hire it out. Any idea on a ballpark figure of what it might cost? I'm just trying to get an idea of whether or not it's worth it to live with the soffit.
    Thanks
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You can tear out all the old piping and run separate feed and return pipes to each radiator form a manifold on the radiator.
  4. jastori
    jastori Member
    May 2, 2008
    Illinois
    Probably the best bet is to call in a couple of local pros for an estimate. It is certainly do-able, and not necessarily a big deal.
  5. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    I've got someone coming to take a look. Doesn't sound like it's a huge deal.
    Another question:
    Wondering if there are issues with running electrical wire and PEX in a soffit together.
  6. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I don't see why not, I see these two run in joist bays every day. But a call to your local inspector might not hurt.
  7. hj
    radiators
    Typically, heating systems are not a "let's try this and see if it works" process. Radiators need larger lines than baseboard heating, and you have to do something to make sure each one gets the proper flow. Call a heating specialist.
  8. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    Had a plumber out today. He said they could replace they main supply and returns with heat pex and connect to the existing lines running to each radiator. Is that really all there is to it?
Similar Threads: Moving Radiant
Plumbing Forum, Professional & DIY Advice Rejoin 1" in-slab radiant pipe after removing rusted section Nov 2, 2008
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
