Moving Into New Home - Changing the Locks - Builder Has a Magic Key to Reset Locks???
Discussion in 'Remodel Forum & Blog' started by Thewaltwhitmans, Jun 8, 2012.
  1. Thewaltwhitmans
    Thewaltwhitmans New Member
    Mar 27, 2012
    North Carolina
    I have received great information from this forum so hopefully this is the best place for this question:
    My mother is moving into a brand new home down the road from us and we got to talking about installing new locks around her house as I have always heard (and followed practice) that when you move into a new home, always rekey the locks. Apparently the builder has told her to go around to all the locks once she moves into the new home and by using her new key the locks will reset themselves to fit that key. Apparently it is a new home thing. Has anyone heard of this before and how likely is it? Apparently there is one key that the builders/etc. can use and once this "magic key" is inserted into the lock, the pins reset and the old key the builder has no longer works, therefore preventing one from having to change locks once they move in.
  2. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
  4. Thewaltwhitmans
    Mar 27, 2012
    North Carolina
    I asked her about these and she said that there were no additional tools - that the builder mentioned something about his key being shorter than the ones he would give her and that when she used her key it would drop another pin, thereby keeping his from working. I am not really that familiar with it though.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I had not heard about these keys before, but my older Kwik Set locks can be changed by the hardware store that sells them. New method sounds great!
  6. hj
    What he told you is true. Just insert her key into EVERY lock and it will stop the construction key from working.
  7. AcidWater
    AcidWater Member
    Oct 14, 2008
    The problem with that is that every house in the neighborhood has the exact same key, except for the last pin. Makes it pretty easy to open the lock; just find a key from the neighborhood and cut duplicates with every height for that one last pin.
  8. hj
    The "construction key" is "unique" to that house, just as the homeowner's key is. The "construction" key will NOT open the other houses in the neighborhood.
  9. preeti22
    preeti22 New Member
    Oct 8, 2012
    CEO
    India
    How it is a possible to one key work for all Locks?
  10. jadnashua
    Locks are keyed alike all the time. You may need to order them that way or find any locksmith to rekey them for you. It is also possible to key (some types of) cylinders to accept a master key. A master key does not mean it will open any lock, only those setup to that specific master. In this situation, there's a key that only opens its own lock, but the master can open many. This is frequently done in larger commercial buildings so a person of responsibility doesn't need to carry hundreds of different keys, but everyone else can only open their door(s).
  11. jimbo
    jimbo Plumber
    San Diego, CA
    You need to study up on locks! What you say is NOT correct. Each house is keyed different. There is a construction MASTER which allows the builder access to EACH house. In fact there may be masters and submasters, etc. But these locks have special tiny little balls in recesses ( I forget the name for this system) and the homeowner key is shorter, so the very first time you put that key in the lock, the ball drops and forever after blocks the masters.
    NOW, would I rekey the locks anyway......YES.
  12. nestork
    nestork Janitorial Technician
    Aug 5, 2012
    Winnipeg
    No, that's not how it works.
    I don't know anything about the key system the OP asked about, but regular Weiser and Schlage deadbolts have 5 places on each key where the key can be cut to one of 8 different depths. So, in the simplest kind of lock, you'd be right; only one key profile would fit each lock.
    However, if you use TWO (or even three) shorter pins in some of the tumblers instead of only one longer pin, then you can have multiple key profiles that will open the same lock.
    It's by using multiple pins in each tumbler that a locksmith can rekey a hundred different locks that each have a unique "tenant" key that will only work in that lock, but still be able to cut a "master" key that will work in all of the locks.
    Medeco Locks are considered the most secure locks because Medeco keys can't be copied in a regular key cutting machine. That's because Medeco keys have some of their teeth cut at an angle to the key, and regular key cutting machines can't make that kind of cut. Only professional locksmiths have access to Medeco key cutting machines, and locksmiths will ask to see identification and check with Medeco to see if the ID matches the registered owner of that key before cutting a duplicate.
  13. Alex Burkeva
    Alex Burkeva New Member
    Sep 8, 2015
    Los Angeles, California
    I agree that medecos are more secure then your average lock. If that is an option for you I would get that installed for your home. For the Smart key locks all you have to do is put in the old key and use the Smart Key function to put in a new key and have it work. Either way if you wouldnt like to change the locks I would call a locksmith to come in and rekey your locks to a new specific key. So after he does that no one will have the key to your home even if they had the master would no longer work.
  14. Magneto
    Magneto Member
    Jul 29, 2015
    Stanford, Connecticut
    The master key will not open any lock, and these new sets of keys that are mentioned are seemingly pointless after the initial consumer has used their key and released the final pin of the lock. This renders all other prior keys useless. Locks and keys work through a synchronicity, the slightest change will render them both useless.
  15. hj
    In fact, some locks have a device that you insert into the lock, turn it 90 degrees, then insert ANY OTHER key and it is instantly rekeyed.
  16. Alex Burkeva
    Sep 8, 2015
    Haven't heard of anything like that but it sounds like smart key locks if anything. I think it's illegitimate. I was going through a similar situation so I just went to google and typed in "should I change my locks after moving into a new home?" and stumbled upon a solid article that gives some expert advice.
  17. jadnashua
    Maybe one of the first things I'd want to know about the installed locks is what security grade do they have? If it was a grade 3, I'd probably consider changing them to at least a 2, and maybe a 1. This defines how easy or hard it is to force open among other features. Of course, the quality of the door and framing plays a part, as even the strongest lock is useless if the bolt isn't projecting into something solidly reinforced or the door is flimsy. Having breakable windows on a sidelight nearby may mean they just break those, and reach in and open the door. Lots of things to consider.
    Good-wrench likes this.
  18. Good-wrench
    Good-wrench New Member
    Oct 18, 2016
    Texas
    Come on does anyone know what they are talking about? I'm actually an old locksmith and yes even Kwikset still makes these locks with "contractor" pins or actually little balls that drop out once the owners key is used.. The contractor- builder gets his keys out and gives the new owners their keys.. They are not "masters" or fit any other house in the sub-division. All they ask is that you not use your "owner keys" until you no longer want the contractor entering the property. His key will no longer work once your key is inserted and rotated the first time it's used.. The locks can be rekeyed by any competent locksmith and they may be able to place the "balls" back in and let the contractor finish too!
Similar Threads: Moving Home
Remodel Forum & Blog Moving a toliet flange over between floor joists Yesterday at 10:51 AM
Remodel Forum & Blog Bonding agent for PIA regrout job. I want 4th time to be the last. Tenant moving in. Dec 22, 2013
Remodel Forum & Blog Removing Ceiling made of drywall, chicken wire, and plaster Nov 28, 2012
Remodel Forum & Blog Tips and Tricks on Removing Top Mount Cast Iron Sink Jul 2, 2012
Remodel Forum & Blog Moving W/D and floor drain Feb 21, 2012
