moving closet flange sanitary t or wye?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by akmacs, Jan 31, 2010.
  1. akmacs
    akmacs New Member
    Dec 22, 2009
    Anchorage, AK
    Hi, I am moving a closet flange and had a question regarding which abs fitting to use when reconnecting to the vent stack.
    I will be cutting the vent line a bit below the subfloor and drain line to the right of the 90 degree fitting. I will then install a new coupler and run new abs pipe out to the left, reconnect to the vent line and go out through the drywall which leads into my garage (I will box it in and cover with fire rated drywall) and come back up through the floor and up to the left side of the joist it used to sit next to. You can see where the floor joist was notched a bit for the old closet flange.
    From what I have read a sanitary t could be used as it is connecting only to a vent line. Any reason to use one over the other?
    Hope my explanation makes sense, I was going to add text to the photos but forgot to install photoshop on the laptop :mad:
    Thanks for the help!
  2. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    I think you are planning on using a san tee on its back in place of the existing 90? We're not allowed to use a san tee on its back here. We would use a combo (wye,45 combination).
  4. akmacs
    akmacs New Member
    Dec 22, 2009
    Anchorage, AK
    If I used the sanitary t it would lay on its back. I wondered if that would be ok as I have read a couple threads here that said it violates code in most places. So it would be best to use a fitting like is in the photo below? I think I would need a 90 and not a 45 as my vent is straight up from the horizontal drain line.
  5. akmacs
    akmacs New Member
    Dec 22, 2009
    Anchorage, AK
    dcelite, I reread your post again and I think what you are saying is to use the wye and then a 45 also?
  6. hj
    You misunderstood when a sanitary tee can be used. It can be used in a VERTICAL line, regardless of whether it is "just a vent" or not. It CANNOT be used in a horizontal drain line, period, at least under most codes.
  7. akmacs
    akmacs New Member
    Dec 22, 2009
    Anchorage, AK
    dcelite and HJ, I will use a wye and not a sanitary tee, does it make a difference if I use a wye/45 with another 45 or a wye/90?
Similar Threads: moving closet
Plumbing Forum, Professional & DIY Advice Removing iron closet flange Apr 14, 2016
Plumbing Forum, Professional & DIY Advice Moving Closet Flange in Slab 1.5" to Correct Rough-In and Offset Oct 3, 2014
Plumbing Forum, Professional & DIY Advice Moving washing machine to master closet Mar 22, 2014
Plumbing Forum, Professional & DIY Advice Removing lead closet bend? Mar 5, 2013
Plumbing Forum, Professional & DIY Advice Moving a water closet Dec 20, 2009
