moving cast iron tub
Discussion in 'Shower & Bathtub Forum & Blog' started by Greggs, Sep 19, 2010.
  1. Greggs
    Greggs New Member
    Sep 19, 2010
    Margate, n.j.
    I am remodeling a very small bathroom. It is a limited space. I want to install 315lbs cat iron tub. The alcove is 60"x 32". There is an old radiator sticking out right in front of this space. Even if I remove the cover and radiating elements, there will still be piping coming out of the floor and wall. This will prevent me from sliding the cast iron tub into the alcove. If we lift it there is not any room to maneuver. does anybody have any ideas about jacks or lifts ect. I would have to lift it 21" off the ground and move it almost all the way and then lower. Also I would have to work from the skinny end of the tub in a 3'x3' spaceHelp anybody? greggs
  2. jimbo
    jimbo Plumber
    Assume you need to open up more wall than you think you would like to ...down to the studs. Sometimes, you can then have enough clearance to lay the tub on its side...apron down ( protect the floor and the apron with heavy blankets. Try to angle it into the space, then you may have clearance to tilt it back down into normal position.
  4. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    Do you have room to "walk" the tub in vertically into the alcove. That's how I did mine because I could not just slide it in.
  5. hj
    There is probably a way, since I install mine into recesses all the time, but the process is NOT something I would want to try to describe in detail and expect you to be able to follow the instructions.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Try a ceiling rail made of an iron rod or thickwalled iron pipe with some type of pulley that rides on it.
    http://www.google.com/imgres?imgurl...ndsp=30&ved=1t:429,r:17,s:59&biw=1474&bih=805
    It will give you horizontal movement with only two small holes in the ceiling to attach the rail to the ceiling joists with cabling at each end of the rail. The rail hangs a few inches below the ceiling surface.
    Get cable with a working strength of 300 pounds or an ultimate strength of 1200 pounds.
    http://www.engineeringtoolbox.com/wire-rope-strength-d_1518.html
    Suspend the tub with rope and a block and tackle, which give you vertical movement.
  7. decorsuite
    decorsuite New Member
    Sep 23, 2010
    Chino, CA
    Sounds like your limited in space. I would suggest you tilt and angle the tub until it fits.
    Johnson
    DecorSuite Inc.
    www.decorsuite.com
Similar Threads: moving cast
Shower & Bathtub Forum & Blog removing overflow on cast iron tub obstructed by tabs Sep 11, 2014
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Price Pfister Avante, Help with removing trim plate Nov 14, 2016
