Moving basement toilet drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 7474, Dec 8, 2008.
  1. 7474
    7474 Member
    Dec 8, 2008
    Moving toilet location in basement slab.
    I have removed all the concrete and am ready to move the waste pipe for my toilet. I currently have a Sioux Chief TKO toilet flange (model 883-AT) installed and I will be replacing with the same. http://www.siouxchief.com/B_Product_Detail.cfm?GroupID=481550
    This flange can go inside 4" pipe or over 3" pipe. Hopefully I can explain this properly. Currently, the set-up is the flange is installed inside a 90 degree elbow with 4" opening that reduces to 3" that connects to the waste line. The problem is that I cannot find this 4" to 3" reducing elbow at Home Depot or Lowes. Is it OK to simply put the flange over 3" pipe or is there a reason it is set-up this way in the basement slab? The set-up on the other bathrooms I have is the same flange goes over a 3" 90 street elbow connecting to the waste line. The basement slab install is the only one that connects into this 4" to 3" reducing 90 elbow.
    Thanks for any assistance you can offer
    [​IMG]
  2. 7474
    7474 Member
    Dec 8, 2008
    Figured it out on my own....
    For those that looked but didn't know and might be interested for their own future use.
    The 4" to 3" elbow was so that a 4" pipe could extend above floor level before the concrete was poured. Then the 4" pipe was cut flush to the newly poured floor and the flange was dropped in. Couldn't be done with the 3" pipe sticking out of the floor as it would have been surrounded by concrete not allowing it to be solvent welded inside the flange.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Standard procedure is to wrap the pipe with foam wrap and mummify it with duct tape which leaves a good inch around the pipe when it is time to connect the flange.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would consider the 884-ATM to be a much better choice of flange.
    I do not use all plastic closet flanges.
Similar Threads: Moving basement
Plumbing Forum, Professional & DIY Advice Moving basement rough in, need advice Jan 29, 2014
Plumbing Forum, Professional & DIY Advice Moving basement toilet and shower rough-ins Jun 5, 2013
Plumbing Forum, Professional & DIY Advice PVC cracked while removing basement toilet flange Feb 27, 2012
Plumbing Forum, Professional & DIY Advice Moving washer and dryer to basement Dec 9, 2011
Plumbing Forum, Professional & DIY Advice Moving laundry from basement to garage Jan 15, 2011
