Moving and changing shower valve help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zoomzoom3, Sep 17, 2008.
  1. zoomzoom3
    zoomzoom3 New Member
    Sep 3, 2008
    I went from a 34" X 48" pan to a smaller 32" X 48" pan. By doing this I just realized that my shower handles are way off now. I also was planning on switching from a two handle to a single handle moen valve.
    (The left handle is actually where the center of the shower/valve should be)
    1) How would I move the supply lines and valve to work with the new pan.
    2) Can I just use two 45 degree fittings to move the left supply line to the left about 4-6" and then just leave the right supply line alone.
    3) Does it matter how high I start the 45's.
    Any other suggestions.
    Thanks in advance,
    dan
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    the wall looks to be wide open. I would do what ever it takes to put the valve were you want it to be. You have the choice to place fittings anyplace you like.
    good luck
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would replace that valve while the wall is open with a pressure balanced mixer.
  5. hj
    valve
    IF you use the correct valve its openings will be on the sides, not the bottom so you can run the lines anyway necessary to get them into the proper position.
Similar Threads: Moving changing
Plumbing Forum, Professional & DIY Advice Moving, reducing and changing 4" cast iron vent pipe Dec 9, 2004
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Today at 6:24 AM
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
