Moving a stove
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bassman, Feb 7, 2007.
  1. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I'm moving a gas range across the kitchen and am thinking that all I need to do is extend the gas line across and up through the wall plate into some sort of flush-fit box in the wall behind the range. Any suggestions? Thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Gas work always requires a permit, even if your jurisdiction allows a homeowner to do the work.
    Depending on how far you have to move, you could go straight across through the studs, but it would be better to go up, across in the attic, and then down again. Boxes are not typically used for gas. A nipple comes straight out of the wall to a valve. Check the rough in spec for your specific stove as to where the the valve should be. This work will need to be done in threaded black pipe.
  4. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I have a permit for kitchen re-do that covers this. The gas line will go under the floor in a crawl space. I guess my main question was whether or not it comes up through the wall plate and then out the wall where it needs to be. I see where there is an indentation in the back of the range where the valve sits so the range can be pushed flush with the wall. It's a small, narrow kitchen. The line is moving only 8 feet to the new wall.
  5. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I've yet to see a gas valve in a wall box but I don't see anything wrong with it. You could use a washing machine or icemaker box and adapt to your needs with no problem if you just feel the need to put it in a box in the wall.
  6. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    I bought 6 cute little gas valve boxes on e-Bay 5 or 6 years ago. I just used them all up save one. I seldom do new houses so they sat a long time. They are neat. I don't know the manufacturer.
  7. hj
    box
    WardFlex for one makes a termination box for their CSST lines. But for this person the valve into an elbow outside the wall in that stove recess should work.
Similar Threads: Moving stove
Plumbing Forum, Professional & DIY Advice Moving bathroom sink water supply lines Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Moving washing maching 90 degrees to new wall Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
