Moved the trap, right?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by andruesw, Nov 11, 2006.
  1. andruesw
    andruesw New Member
    Oct 9, 2006
    If you recall my old andruesw thread, I was contemplating a running trap or Rube Goldberg run to my existing p-trap for a new basement shower. I've since dug deep, removed the old p trap and run a new "unique" line to the drain. I have ensured proper elevation (quarter inch per foot), but have I created too much of a curve? Anything fundamentally wrong with this?
    Thanks.
  2. jimbo
    jimbo Plumber
    Is this an april fools joke? The black curved pipe we see is PERFORATED corrugated COREX landscape drain. Please don't tell me it is connected to any part of your DWV system. I would like to know why it is in the house at all!
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I would like to know what the black, corroguated, perforated pipe is for also.
    As far as the DWV pipe goes you need to bust the concrete up more and get rid of all the bends and make the run straight and where is the vent?
  5. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Looks like Georgia red clay to me. Or Arizona.
  6. vaplumber
    vaplumber Guest
    I hope the black pipe is what I think it is. Ive seen these installed once upon a time to drain water from under the slab in high water table areas. Thats what it looks like to me.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    It also looks like 1.5" but it is hard to tell from the pic. It should be 2".
  8. hj
    pipe
    The black pipe might be to eliminate Radon. If you had extended the straight piece of pipe further and rotated the trap the other way, you might have been able to eliminate that second 45 degree turn. But otherwise what we can see will work. No guarantees about what we cannot see, such as a vent.
  9. andruesw
    andruesw New Member
    Oct 9, 2006
    Black Pipe
    Not sure what the black tubing is. Could be a French drain or something else. (Almost looks like a perforated leaching line or something up close.) I simply dug underneath it, so no, it's not connected to anything PVC-related, just obscuring the PVC in the picture. Thanks to all who replied.
    And the vent is about 3-4 feet from where that bend is.
Similar Threads: Moved trap
Plumbing Forum, Professional & DIY Advice Low well press. + empty press. tank? Just moved in :( Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Soldering removed; flux residue remains? Oct 27, 2016
Plumbing Forum, Professional & DIY Advice Moved and replaced sink. Now slow draining Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Does this compression fitting look like it would leak if removed? Jul 5, 2015
Plumbing Forum, Professional & DIY Advice Can this 1/2" copper line be moved? Jun 4, 2014
