move vent wall back 12"
rcm650
California
I got a question about moving my vent back by 12" to accommodate an extended shower. Help!
I have a sketch of what is now and how I want it to be.....I have very little space to work in.....Thanks...rcm650
Cacher_Chick
Test, Don't Guess!
You did not specify, but the shower trap and drain must be 2". Your plan will not work because the dry section of vent cannot be horizontal nor can a sani-tee be used on it's back. You will have to move the drain and the vent.
There is no way your design would EVER be approved. You are essentially installing the sanitary tee backwards. The sanitary tee is NOT on its "back" it is on its "face", which is even worse.
