Move toilet in Master Bath
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TRoeschen, Feb 26, 2014.
  1. TRoeschen
    TRoeschen New Member
    Feb 26, 2014
    Wisconsin
    I want to move a toilet in my master bath. I plan on reconfiguring an existing 4" drain which has a 2" shower drain and a utility sink drain currently attached to it. The toilet will be about 3-4 feet to the stack. I'll need to remove the 2" PVC drain from the 4" cast iron drain and replace it with a 3" PVC pipe which will I reduce to 2" near the top to connect to the vent. I'll make a new connection for the 2" shower drain and a new connection for the 3" toilet drain. Do I need to vent the toilet? I have an extra vent pipe from the old shower location. Should the shower drain be above or below the toilet connection or doesn't it matter? Is it ok to have the laundry sink drain below the toilet drain? I've attached a picture of the current setup.
    Thanks
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
  4. hj
    I am not sure what you are doing with those TWO white/yellow pipes, but one, or the other, is both extraneous and illegal. The way you have it drawn, that would be the left hand one. As drawn, the shower MUST be above the toilet connection, but since the sink has its own vent, it can connect anywhere.
  5. TRoeschen
    Feb 26, 2014
    Wisconsin
    Sorry for the confusion. The yellow/white lines are the new pipes. The line coming from the right upper corner of the picture would be the new toilet drain. The line that is drawn around the 2" riser from the cast iron drain indicates the section of the 2" pipe that will be removed and replaced with a 3" PVC pipe. There is only one pipe in this area.
  6. TRoeschen
    Feb 26, 2014
    Wisconsin
    I've added a current picture and proposed configuration. I hope this makes things clear.
    Thanks again.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The connection of a vent stack with another vent may not be less than 38" above the next higher floor level where the plumbing fixtures are vented, but in no case lower than 2" above the elevation of the highest flood level rim of any fixture served by the vent.
  8. TRoeschen
    Feb 26, 2014
    Wisconsin
    The shower vent (2"), laundry sink vent (1.5"), and the unused vent (1.5") go up through the wall and connect together at 40" above the 1st floor to a 2" pipe that goes up into the attic. If I add the toilet drain do I have to vent it separately or can it use the same vent as the shower?
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Is the lavatory not connected to the pipe which is also serving to vent the shower? A sharp inspector would not allow a dry vent to run horizontally below the flood rim of the highest fixture on the stack.
    The toilet and shower could be tied into the stack using a sanitary tee with a side inlet for the shower. The fixture drains need to enter the stack at the same level if you plan to avoid a re-vent.
  10. TRoeschen
    Feb 26, 2014
    Wisconsin
    The lavatory [i assume you mean sink] is on the other side of the bathroom. It has its own vent and it drains into a separate 3" stack vent where the old toilet was.
    So my options are [I think]
    1. Get a sanitary tee with a side inlet and connect the 2" shower drain and the 3" toilet drain to it. Reduce the top of the 3" stack to 2" and connect it to the 2" vent.
    2. Connect the 2" shower drain to the 3" stack above the toilet connection to the 3" stack. Vent the shower drain to the unused 1.5" vent pipe and vent the 3" stack out the top to the 2" vent pipe.
    Are both these options correct?
    Thanks for your help
  11. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Yes, but again, any section of vent must be vertical at least until it rises above the flood rim of the highest connected fixture.
  12. TRoeschen
    Feb 26, 2014
    Wisconsin
    Thanks for being patient, I'm still learning. In my current setup the vent pipes look like are slightly pitched before they hit straight vertical. Is it ok to do this when I connect the vent pipes to the vertical vent pipes?
  13. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Your current shower vent does not comply with good plumbing practices or the plumbing code. There cannot be a horizontal section of dry vent below the flood rim of any of the fixtures which it serves. Horizontal would mean any angle less than 45 degrees.
  14. TRoeschen
    Feb 26, 2014
    Wisconsin
    How would you make this work?
  15. Terry
    Aug 17, 2004
    The trap arm for the shower comes off the vertical. If you have a lav on that vertical, run it as 2" and it's considered a wet vent.
    Below the trap arm, then you can throw on a 90 and aim it toward the waste stack.
    Below the trap, it's getting washed.
  16. TRoeschen
    Feb 26, 2014
    Wisconsin
    There is no lav in this setup, its on the other side of the bathroom. So if I use a 3" san-tee with side outlet I can connect the shower to the side outlet, the toilet to the 3" opening and a 2" vent to the top opening. The toilet will be 46" from the stack and the shower drain is 19". Thanks for your help.
Similar Threads: Move toilet
Plumbing Forum, Professional & DIY Advice Replacing Toilet Water Valve, should I remove old ferrule and compression nut? Aug 9, 2015
Plumbing Forum, Professional & DIY Advice Extending toilet drain/flange higher - how? Valve - can I move the handle? Jul 20, 2015
Plumbing Forum, Professional & DIY Advice Planning to move toilet... and found this. Jan 10, 2015
Plumbing Forum, Professional & DIY Advice Modifying cast iron drain to move toilet? Feb 1, 2014
Plumbing Forum, Professional & DIY Advice Toilet move Dec 3, 2013
