Mounting a water meter ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Spydrweb1977, Aug 21, 2012.
  1. Spydrweb1977
    Spydrweb1977 New Member
    Aug 20, 2012
    NJ
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Not all meters will operate correctly in the vertical position. You need to find the exact model and find out first. Either way though the meter should be hard piped on either the inlet or outlet for a distance so that at least two split ring hangers can be used to hold the pipe.
  4. Spydrweb1977
    Aug 20, 2012
    NJ
    Split ring hangers were what I was thinking, thanks or the input. I will verify the exact model and make sure it is good for vertical operation. Based on the literature on neptunes site, I think I will be good to go, but I will verify the model first and plan accordingly. Thanks again.
  5. Spydrweb1977
    Aug 20, 2012
    NJ
    Ok, so I verified the model as a 5/8 T 10, and per specs it has a "floating chamber design unaffected by meter position or in line piping stresses" so it looks like vertical mount is a go :) it also says it has bayonet style mount for the gauge allowing in line serviceability. Does that mean I can twist off the gauge and rotate its orientation? As is, the gauge will be upside down when it's in place... I don't mind that, just not sure if it affects the operation...
  6. ballvalve
    Dec 28, 2009
    northfork, california
    never saw a rotateable readout. maybe a digital can do. I would call them.
  7. hj
    It means the dial is easily removable, but that does not mean it can be oriented differently, but it could be if the "bayonets" are 180 degrees apart.
  8. Spydrweb1977
    Aug 20, 2012
    NJ
    Well, called Neptune today, and it looks like I'm doing a horizontal install after all. They said they have only tested the meter this way and would not recommend vertical, even though their literature states the design allows it.... Better safe than sorry... I can still flip the readout I I want though, apparently there a four position you can place it in with the bayonet setup.
Similar Threads: Mounting water
Plumbing Forum, Professional & DIY Advice Sink pump discharge pipe mounting Yesterday at 5:18 AM
Plumbing Forum, Professional & DIY Advice Mounting copper manifolds? Nov 9, 2015
Plumbing Forum, Professional & DIY Advice Location and Mounting/Support of pressure regulator Sep 29, 2015
Plumbing Forum, Professional & DIY Advice Best mounting depth for Hansgrohe i-Box? Apr 11, 2015
Plumbing Forum, Professional & DIY Advice Help Mounting Hudson Reed Thermostatic Bar Shower Mixer Valve. Nov 2, 2014
