Mounting a AS Glenwall
Discussion in 'Toilet Forum discussions' started by aviator_edb, Oct 15, 2008.
  1. aviator_edb
    aviator_edb New Member
    May 31, 2008
    Ok, the day of reckoning is here. I will be mounting my glenwall toilet this evening. I funally got a helper. Anyway, I know the top right bolt is jsut finger tightened then 1/4 turn but what about the others? Is there a good rule of thumb to follow on hwo tight those are? I do not want to crack the toilet. ....
  2. hj
    Gleanwall
    IF you do it correctly, the other three bolt will have nuts on them flush with the finished wall. Then the large metal washers go onto the bolts, (this gives the 1/8" clearance specification). You put the toilet on the bolts, (set it onto the two lower ones and then tilt it up onto the top ones, then catch the upper left nut to hold it). Then place the lower nuts on the bolts and tighten all three. You will only be able to tighten them so far before the bowl will be clamped against the steel washers. Finally place the upper right hand tight and a quarter turn more. DONE.
    [​IMG]
Similar Threads: Mounting Glenwall
Toilet Forum discussions Caroma Sydney Rear Outlet Floor Mounting Oct 1, 2015
Toilet Forum discussions Toto Neorest MS950CG Front Mounting Block Jul 26, 2015
Toilet Forum discussions Toto Aquia Mounting Flange Apr 6, 2014
Toilet Forum discussions Mounting Bolts For Wall Hung Toilet Apr 3, 2013
Toilet Forum discussions how to square up mounting holes for closet bolts Sep 1, 2012
