Molo
Hi all,
I have a question about running pvc drain lines and how to get the required slope. My question revolves around tying a horizontal into a sanitary T. The sanitary T connection comes off parallel to the ground. (90 degrees from the vertical). How can you run a pipe into this T, and achieve the desired slope for a drain? It seems as if the horizontal would be forced into a level position by the way T that you are inserting it into.
Probabaly a dumb question, but I ain't an expert.
TIA,
Molo
TIA,
Molo
