MORE HELP!!cracks in fiber-glass shower walls..
Discussion in 'Shower & Bathtub Forum & Blog' started by DIY-new, Feb 11, 2005.
  1. DIY-new
    DIY-new New Member
    Feb 9, 2005
    hi all,
    looks like I have another one coming my way..
    I noticed that there are couple of cracks in my fiberglass-shower walls.
    to clarify , cracks are in the shower walls onlu and not the bathtub.
    any one had any experience with with that ?
    i got some people telling me that there is no fix for fiberglass cracks.. if you fix some it will just find other place to crack.. true ? any risks if i just leave it like that ?
    any help appreciated.
    thx.
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    There are fiberglass repair kits out there for tubs, showers and surrounds, but I've never used them so I cant state if they actually work or not. I have seen a professional repair done to a shower though and you'd be hard pressed to find the repair. One question in my mind however is why did they crack to begin with? Someone slip and fall into a wall or are there settling issues with the house, etc.
    I'd consider just replacing the walls. You can buy fiberglass surrounds for the tub or even replace the fiberglass with tile or marble walls. There may be other fixes but I dont think I'd want to worry about a leak through the shower walls messing up the ceiling below.
    Good luck
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    For temporary repair of hairline cracks or chips in fiberglass tubs and showers, you can use Appliance Touch-Up (AT) liquid, which actually is made to repair chips in white enamel appliances. It drys hard as a rock.
    You can find it at most appliance stores and many hardware stores.
    To use it, clean and dry (I use a hairdryer) the crack or chip. The AT liquid comes with a little cap brush like nail polish, and you just brush it on. Smooth and clean up the edges with a Q-tip dipped in acetone (nail polish remover). Let it dry overnight.
    It shrinks a bit, so you may have to apply it more than once.
    I've had good luck with it, and it will seal it until you repair it properly or replace it.
    Good Luck!
    Mike
Similar Threads: MORE HELPcracks
Shower & Bathtub Forum & Blog More silicone??? Dec 4, 2016
Shower & Bathtub Forum & Blog One drain or more in shower Aug 21, 2014
Shower & Bathtub Forum & Blog Traditional shower pan - can anyone point me to more info? Jul 3, 2014
Shower & Bathtub Forum & Blog No more Lift Arm's for the Sink Stopper: World's First pop Down Drain May 20, 2014
Shower & Bathtub Forum & Blog Whats the difference between thin-set mortar and latex mastic? Whats more common? Apr 14, 2013
