More critique wanted
TheZster
Fort Collins, Colorado
Still remodeling the basement (adding a bathroom). Attached is a photo of my drain setup for two sinks and a bathtub. You can see the main stack and the spaghetti bowl of attachments. From the top I've got - Main Stack with cleanout - Sanitary T for sink draink - Another Sanitary T for another sink drain - Another Sanitary T for the bathtub drain along with a Vent (2inch) and P-Trap - Below all that is the main drain into the slab and a toilet drain. I would appreciate any positive critique on the setup before I call the inspector. Hopefully it's all good. There will be additional/separate vents for the two sinks to be added after piping is finished and walls are up. Thanks in advance.......
Plumguy
MA
From what I can see it looks good! Is there anything being used on the stack above the sinks? If not then as long as your'e sink traps are within 6 feet (because you used 2")from stack to trap weir (90) then you would not need to add any more vents.
TheZster
That would be the easy way out - right? Unfortunately, the upstairs bath and laundry room drain into the main stack. I intend to vent everything in the new basement bathroom to an existing vent on the other end of the basement that currently serves another bath. That should be legal and proper.
