Monoflow vs. Strait loop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Peter57, Nov 27, 2011.
  1. Peter57
    Peter57 New Member
    Nov 27, 2011
    Hi all:
    I'm replacing a 60 year old copper/monoflow system with PEX, and am considering a strait through loop. I could use some advice.
    The heating is for the first floor, 1 zone, about 750 sq. ft. I plan to branch off from a common 1 inch PEX feed into two 3/4 inch loops of approx. same size. The baseboard is Hi output slantfin (80) with 3/4 inch copper. Strait thru is so much simpler than monoflow, but are their disadvantages with strait thru? Why was monoflow even used in the first place? Am I doing the right thing??
    Also, do I need bleeders in a strait thru loop? (I will put shutoff valves in each zone)
    Regards, Peter
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    With monoflow Tees, you can shut off each baseboard radiator without shutting off the flow for the entire loop. If you have no need to be able to shut off individual radiators in the loop, I don't know if you'd need those tees. I never worked with PEX, but I've read that the effective sizes are different than those of copper because of the wall thickness, so you'd need to go up a size to get the same flow rating.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Go with loop piping, there is way less pump head loss. I would bring each loop back to the boiler manifold rather than split 1" pex.
  5. hj
    quote; Go with loop piping, there is way less pump head loss
    I doubt that that is true because a Mono-Flo system uses a larger main "loop" which creates LESS flow restriction.
  6. Peter57
    Peter57 New Member
    Nov 27, 2011
    Thanx. I don't really need to shut off each baseboard. I've resched the PEX wall thickness and you're right, it is a bit smaller.
Similar Threads: Monoflow Strait
Plumbing Forum, Professional & DIY Advice adding a loop in a monoflow system Aug 26, 2007
Plumbing Forum, Professional & DIY Advice Monoflow problem Jan 31, 2007
Plumbing Forum, Professional & DIY Advice Monoflow to Series loop conversion Aug 30, 2005
Plumbing Forum, Professional & DIY Advice Adding to a Monoflow Heating System Jun 8, 2005
Plumbing Forum, Professional & DIY Advice Monoflow T installation. Sep 27, 2004
