Monoflow sytem Q's and adding a radiator
Discussion in 'HVAC Heating & Cooling' started by jaytech33, Aug 23, 2009.
  1. jaytech33
    jaytech33 New Member
    Aug 23, 2009
    Hello all,
    I am looking to add a radiator in one room of my basement. The room is 12x20 three outside facing walls, non insulated. Basement is 75% below grade. Winter temp in this room can get as low as 55 degrees. I see myself having two options, add a zone, or tap into existing system. After doing much reading about my system I am starting to get more confused, not better educated!
    Hydrotherm HC-85B 68,000 BTU boiler, cast iron radiators all on the first floor. The first potential problem I find is that there are many unused, capped off monoflow tees! From what I read this is not a good thing. The system has 7 cast iron radiators, each one uses one monoflow T and one regular T. What I found was that at each radiator there is an extra monoflow and regular T. Why? no idea, this is how I bought the house.
    Since I have all of the extra T's can I use them to run extra radiator(s)? Can I mix a baseboard radiator with the cast iron? all of the main radiators feed off the pipe located at the basement ceiling, the new radiator would need to have the pipe come down off the ceiling pipe and back up.
    This is the direction of system flow: boiler, living room, hallway, kitchen, bedroom 1, bedroom 2, bathroom, dining room, circulator pump, boiler. This new radiator would be between bedroom 1 and 2.
    I just want to keep this room warm since it is now housing quite a few fishtanks ranging from 50 gal to 600 gallon!
    Thanks in advance for taking the time to read all of that!
Similar Threads: Monoflow sytem
HVAC Heating & Cooling Monoflow system upgrade to combi Sunday at 2:40 PM
HVAC Heating & Cooling HW monoflow loop Feb 22, 2013
HVAC Heating & Cooling Can Monoflow tees lie flat to floor joist or hang below Apr 27, 2010
HVAC Heating & Cooling Replacement of a hot water iron pipe monoflow to pex or smaller copper Jan 15, 2010
HVAC Heating & Cooling Monoflow Hot Water System - can I use to cool? Sep 24, 2009
