Mold in the attic
Discussion in 'Remodel Forum & Blog' started by crivera, Sep 28, 2009.
  1. crivera
    crivera New Member
    Sep 28, 2009
    illinois
    I have mold in my attic due to poor ventilation, the ventilation problem has been repaired and now I'm in the process of cleaning the mold. I am using a strong solution of bleach and water. I'm wondering if the insulation has to be replaced.
  2. jimbo
    jimbo Plumber
    In general, if insulation was moldy, it was probably wet. I don't think you could ever adquately dry it out or clean it. Best to get it out, treat mold underneath, and redo the insulation.
    Bleach is not recommended as a treatment for mold, and does not necessarily kill the spores. Get professional mold remediation products from a good hardware store.
  4. drick
    drick In the Trades
    May 16, 2008
    If the insulation was wet, or was in contact with the mold pull it out.
    Also as previously stated, while bleach will probably kill some of the mold it may not entirely wipe it out. In any event,I'd continue with the bleach, but would also look at encapsulating the mold by applying a special paint over it. I'm not sure if the big box stores have it, but I have used it in the past so I know its out there someplace.
    -rick
  5. Cookie
    Cookie .
    Oct 7, 2005
    I had to deal with mold in the bathroom from a leaking roof in 2005, and I got my homeowners to pay for it, they covered mostly everything, and everything went. So now, the bath is mold free. My homeowners was great, they even sent out a sample of the mold to be tested and it was confirmed as the kind to cause pneumonia, which at the time, I was also, dealing with. So, it is really important you pull out all that insullation just in case, and if it is wet in your attic yet, you might need to rent a dehumidifier and an air-scrubber machine, and let them run until, it is dry. For me, it had taken a solid week to dry in the floor joists, in the walls, etc., but it was worth it. Also, I don't now if you mentioned this, or not, but do you have a bathroom fan venting into the attic? You might also, need to add some roof vents, if you haven't already.
  6. jimbo
    jimbo Plumber
  7. muquidir
    muquidir New Member
    Oct 9, 2009
    USA
    Thanks for the suggestion, I wish it had worked.
  8. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    My daughter lives in Mississippi. Her house is on a slab and she had 30" of water throughout the house. After the drywall was removed we were told to mix some paint with the bleach and spray it on the exposed framing. It worked great.
    John
Similar Threads: Mold attic
Remodel Forum & Blog How to clean attic mold? May 5, 2007
Remodel Forum & Blog possible mold issue? Dec 19, 2013
Remodel Forum & Blog Mold inside exterior walls, WTF!!! Feb 26, 2013
Remodel Forum & Blog Sears moldy washer suit can proceed as a class action Nov 13, 2012
Remodel Forum & Blog Basement refinishing- how to keep mold away Feb 29, 2012
