Moisture protection beneath CBU floor?
Discussion in 'Remodel Forum & Blog' started by Fistor, Jul 15, 2008.
  1. Fistor
    Fistor Geotechnical Engineer
    Mar 18, 2008
    Vancouver, BC
    Hi -
    Just a quick question here... I plan to put down some cement board over the subfloor, prior to placing tile.
    My question: do I need to add some sort of moisture protection (e.g. poly sheet) beneath the cement board?
    I know this is advisable behind cement board wall for a tub surround, but then again, there is much greater chance for water infiltration. Still, spills, etc. can occur on a bathroom floor, so I thought I'd see what everyone thought...
    thx!
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I did not put any under mine, and I do not recall ever hearing I should ... and personally, I believe I would rather have a spill pass on through into the sub-floor rather than pooling all around my heating wire.
  4. B2CHR
    B2CHR New Member
    Jul 1, 2008
    Remodelng
    Central NC
    No vapor barrier. I allways set the backer board in thinset so you can't use a VB. If I have to tear up the floor first then I put 30pd felt paper between the two layers or plywood.
  5. jadnashua
    Nothing on the floor! Embedding the cbu in thinset is mandatory - this fills in any minor imperfections and provides 100% support for the tile...voids and possible movement are death to tile. Also, use the special mess tape on the seams.
    I'd rather use something like Ditra, though...SO much easier to install, and you can carry all you need for a big room on your shoulder in one trip. www.schluter.com
  6. B2CHR
    B2CHR New Member
    Jul 1, 2008
    Remodelng
    Central NC
    Will have to check into this Ditra. Here alot about it here.
Similar Threads: Moisture protection
Remodel Forum & Blog moisture in attic.... help! Dec 16, 2012
Remodel Forum & Blog Basement moisture issue.. Jul 7, 2012
Remodel Forum & Blog how to reduce the moisture issue on my basemenet? Oct 28, 2011
Remodel Forum & Blog Paint / Moisture in Bathroom Oct 17, 2010
Remodel Forum & Blog Moisture Project Jan 16, 2007
