Moentrol Legend acrylic index button?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by charles2, Aug 29, 2013.
  1. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    It's definitely a Moentrol dating from 1979, and Moen says it's a Legend and calls the part a "handle insert." But it's no longer available. In the photos, the one on the left is part #15613, which is the wrong color and has an O-ring. The part on the right is what I need; it has no O-ring but does have 4 tabs on the back. As you can see, the black part is a bit thinner than the new part. Both diameters are about 1-5/8". Anybody know where I can find it? If not, and 2 tabs are broken off the old part, how should I try to reattach it?
  2. hj
    Just buy a new handle and install it.
    [​IMG]
  4. jaypak
    jaypak New Member
    Aug 31, 2016
    Nebraska
    I have the exact same part. Couldn't find replacement. Reattached by putting Loctite vinyl/plastic/adhesive glue on the remaining tabs. Should still be able to pry it off if I need to get to the handle screw.
  5. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
    I would just try some clear silicone on it.
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Import replacement buttons are available, for instance Lasco 0-6159 (15506 bulk).
Similar Threads: Moentrol Legend
Plumbing Forum, Professional & DIY Advice Moentrol Temperature Control Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Old Moentrol Valve? Feb 25, 2015
Plumbing Forum, Professional & DIY Advice Moentrol - Tub or Shower Port? Feb 16, 2014
Plumbing Forum, Professional & DIY Advice Moentrol service stops leaking Jan 7, 2014
Plumbing Forum, Professional & DIY Advice Moen 3520 Moentrol valve 1/2" Apr 10, 2010
